Tricks For Removing Rusty Rear Axle Carrier Bolts?
Trying to do some Strut/Brake/Swaybar link work on the 99 Corolla with 150k on it. Spent most of its life in Southern Missouri, but in its two winters in NE Iowa, those long a$$ bolts don't wanna budge!! The equivalent bolts on our Subaru(lifetime Iowa car) took some pursuaion to get off,but they did respond to PB Blaster and wire brushing of exposed threads. The Subie also more or less fully encases the bolt shaft while the Corolla leaves lots of shaft exposed on the inside part of the carrier.
Other than extreme heat and more PB Blaster, is there any trick specific to these bolts that will get them out of their "roost"? Even if I get the suspension arms loose from the rear suspension carrier, I'm not sure chucking the whole mess in a bench vise is going to make it any easier. BTW, the PB Blaster is on its second week of soaking and still no budge and my shade tree impact wrench is making no progress even at its rated 225 ft./ lbs of torque. I promise that if they come out, they will get the total spa treatment with Anti seize compound.
1
Thanks
DM&FS
"What's another word for Thesaurus?"- Steven Wright
