-HELP- Changed 100A fuse now car wont start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-29-2009, 12:54 AM   #1 (permalink)
View SuperGM's Photo Gallery
-TOYOTA COROLLA 2000 - After blowing 2 fuses the 100A and 15w interior fuse,when changing the head light .. I can't start the car ?
Everything works the stereo...headlight etc .. but the car is not turning over, only the fan starts .? >? please help asap .
Thanks !
SuperGM is offline   Reply With Quote
Old 10-29-2009, 05:53 AM   #2 (permalink)
View glow-plug's Photo Gallery
Standard trans clutch to the floor no floor mat in the way, auto trans vehicle in park try neutral.
Any clicking when trying to start?
Battery power making it to the starter (Test light or multimeter required)?
glow-plug is offline   Reply With Quote
Old 10-29-2009, 10:10 AM   #3 (permalink)
Hmmm - its an automatic - car is in Park but I will try neutral and I'm going to try giving it a jump start today .
Old 10-29-2009, 10:20 AM   #4 (permalink)
View msrdude's Photo Gallery
Could be battery.
Did you check the rest of the fuses? Maybe they are out as well.
Cars that I own:
1996 Toyota Corolla DX
1996 Toyota Camry LE
2007 Toyota Camry SE
msrdude is offline   Reply With Quote
Old 10-29-2009, 10:24 AM   #5 (permalink)
Getaway Driver
Uzzy's Avatar
View Uzzy's Photo Gallery
Which 100A fuse? How did you blow that changing a headlight? I mean is in the fuse panel or is it like a fusable link? Though I think if you blow the fuseable link nothing works. Maybe you fried your starter. Again, how did you pop a 100A fuse in a car while changing a headlight?
Speramus Meliora; Resurget Cineribus
Aut viam inveniam aut faciam
If you have a problem, if no one else can help, and if you can find him, maybe you can hire Uzzy.
'Ich bin ein Detroiter'
Uzzy is offline   Reply With Quote
Old 10-29-2009, 10:32 AM   #6 (permalink)
This how the fuse was blew .. when I was changing the headlight bulb the headlight switch was on - so when I connected the battery there was a small spark and - the head lights where stuck on and none of the light inside worked . So I turned the switch to off and disconnected the battery,when reconnected the headlight lights turned on/off .
And that blew the interior light fuse as well as the 100A - So everything works now but the started is not turning over ..
Is there a fuse for the starter and idea what its called ?
Old 10-29-2009, 10:47 AM   #7 (permalink)
Getaway Driver
Uzzy's Avatar
Could be somthing in-line. Check the cbales from the starter to see if there's somthing. I don't know if there is for sure or not.
Old 10-29-2009, 11:05 AM   #8 (permalink)
Could it be the Starter Relay ? hmmm
I need to fix this ASAP !
Old 10-29-2009, 10:53 PM   #9 (permalink)
The 100 amp looks like it is to protect the alt.
