Fueling problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-29-2009, 06:28 AM   #1 (permalink)
View EASTCOASTER's Photo Gallery
Fueling problem
I go to fill the 2000 corolla and when the pump stops to let you know it is full, fuel comes up the filler pipe and some fuel comes out and down the side of the car. Any idea how to rectify this??
Thanks
EASTCOASTER is offline   Reply With Quote
Old 10-29-2009, 08:11 AM   #2 (permalink)
Crowbar911's Avatar
View Crowbar911's Photo Gallery
There is no mechanical parts on the car that stop the gas flow, so I would think that its a problem with the gas pump. I have a gas station near me that will only fill my car halfway.
Does this happen at all gas stations or only 1?
SCCA First Place 10/25/09. NST
Crowbar911 is offline   Reply With Quote
Old 10-29-2009, 09:40 AM   #3 (permalink)
It happens at all gas stations. I had my gas tank replaced about a year ago and this problem coincides with that replacement. I basically just judge how much the tanks needs and just stop pumping when I think I am close..but would like to fill it up each time
Old 10-29-2009, 09:48 AM   #4 (permalink)
Gearhead
Gameroom cash: $196215
Sounds like the gasoline vent tube (runs from the top of the tank to the side of the filler tube opening) is either unplugged or missing when they replaced the tank. This vent makes sure there is reduced pressure during the filling process, to prevent the fill station's fuel pump to not shutoff in the middle of refilling, but increase pressure dramatically when you start to get close to the top of the tank (by the bottom of the vent tube). This case - that pressure can be high enough to cause the auto shutoff feature of the filling stations pump to kick on. But if that tube is not connected correctly, or missing or otherwise rerouted, may not be generating enough pressure to kick the pump off.
I don't think you have enough room to take a peek at the vent tube. Might almost have to drop the tank to get at it. Since so much time has passed since you had the tank replaced, I doubt you have any options at that shop, unless you have a written warranty in hand. May just have to go by the mileage or by ear (you should be able to hear the gas get close to the top of the tank, sort of whistles as you get close).
Old 10-29-2009, 05:01 PM   #5 (permalink)
Thanks for the replies!!!
