Amber corners - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-30-2009, 02:42 PM   #1 (permalink)
Gameroom cash: $371570
View ilovecorollale's Photo Gallery
Amber corners
I cant seem to find any amber corners on ebay so let me know where u can find those for a 01-02 corolla.
ilovecorollale is offline   Reply With Quote
Old 10-30-2009, 03:00 PM   #2 (permalink)
ロンリードライバー
Gameroom cash: $224935
View all2baka's Photo Gallery
or search the forum
all2baka is offline   Reply With Quote
Old 11-01-2009, 11:00 AM   #3 (permalink)
Crash Tested
View Danimal7's Photo Gallery
Is your car just missing them alltogether or are you looking for an aftermarket part??? Cause if you're missing them from factory then I'm 99% sure that Toyota issued a recall on amber corners, so call the dealership and have them do their magic.
If everything is under control,
you're just not driving fast enough!
'99 Corolla LE 1.8L 1794cc [1ZZFE]
Danimal7 is offline   Reply With Quote
Old 11-01-2009, 11:12 AM   #4 (permalink)
on full afterburner
Gameroom cash: $1345597
You can buy transparent amber spraypaint on ebay or vinyl overlays and cut them to fit.
Old 11-02-2009, 01:27 PM   #5 (permalink)
new to TN
ExDream's Avatar
Gameroom cash: $119500
View ExDream's Photo Gallery
i painted mine myself. i used tamiya color brand model car paint. clear orange. a couple coats and you're set.
ExDream is offline   Reply With Quote
Old 11-02-2009, 10:14 PM   #6 (permalink)
on full afterburner
Originally Posted by Straight98 View Post
there arent many options for the 2001-2002 corner lights, you can get the blackhousing headlights and corners off ebay for around 160, but i hear they arent sealed very well and fog up on the inside. if you decide to paint them i would sugest clearcoating them also to protect the paint from the elements.
Just get RTV clear silicone and reseal the lights once you get them.
Should keep moisture at bay.
Old 11-05-2009, 10:04 AM   #7 (permalink)
jdmgen8's Avatar
View jdmgen8's Photo Gallery
Thats not a bad idea i was just bout to order a set so thanks for the tip
jdmgen8 is offline   Reply With Quote
Old 11-20-2009, 12:24 PM   #8 (permalink)
Do you just spray it on the corner lights or are there certain steps to do it??
Old 11-20-2009, 01:21 PM   #9 (permalink)
Gearhead
Gameroom cash: $196215
^^^ Follow the directions on the spray paint that you intend to use. Most of the spray on tints require a certain amount of prep - will vary depending on what you intend to use.
Old 11-20-2009, 06:45 PM   #10 (permalink)
i might want to use the tamiya clear orange for my corners to make it amber. Does that have steps because i am no experience in spray painting at all never.
Old 11-30-2009, 12:28 PM   #11 (permalink)
btw i suppose autozone or kragen or wallmart dont seel these paint do they?
Old 03-05-2010, 09:11 PM   #12 (permalink)
I couldnt find amber vinyl but orange vinyls on ebay...and what part number is the tamiya clear orange color or just type up tamiya clear orange and it is what it is will pop up...and heard that in order to really get it amber like you need a stained glass spray paint and do couple layers over and over to get amber color?
Old 03-05-2010, 10:58 PM   #13 (permalink)
new to TN
ExDream's Avatar
Just go to your local hobby shop and look for it. And as for prep work, I'd recommend sanding it down a little 800 grit then 2000 grit. I didn't sand mine but it takes a couple coats to get a deep amber. It'll be yellow first. So if u want to get yelow fogs that's like the first 2-3 coats.
Old 03-06-2010, 10:08 AM   #14 (permalink)
Bingo's Avatar
View Bingo's Photo Gallery
Here are some "amber lamps".....
Bingo is offline   Reply With Quote
Old 04-03-2010, 09:08 PM   #15 (permalink)
It was dumb how i ordered these so call to be amber vinyl transparent and they're not. They were pumpkin orange and even wasn't close to being transparent at all.
