My 98 corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-31-2009, 05:25 PM   #1 (permalink)
CorollaCarClub.proboards.
RinconRolla98's Avatar
View RinconRolla98's Photo Gallery
USA My 98 corolla
Today I up graded the front door speakers ....
First you un - screw the handle
Very carefully pull the tab from over the small bar
Then pop up the Handle from where you close the door .
Remove the 2 screws
Then pull up to remove the panel
There is the speaker
You have to chisel the Rivet off Very easy
Then turn the speaker on its fron and on the back you cut off the shell off from the frame , Because you can reuse the frame .
Once you have it removed
Then you stick in your new speaker just as it is ..
Mark the hole spots and make 3 holes
Screw the speaker to the frame that was with the car
Then you put the splash protector back on then hook up and see if speaker is working .
Re-rivet the frame back on
Then you are finished and put the panel back together ... and there you have it my upgrade on a 8th gen .
RinconRolla98 is offline   Reply With Quote
Old 10-31-2009, 05:42 PM   #2 (permalink)
8th gen DIY Rear Strut Replacemant
Today I changed out my Rear Struts ....They were messing up my rear tires .. Auto Zones Gabriel Lifetime Warranty .
This is what the old ones look like ...
First you remove the clip for the brake line
Then you remove this Satbilizer link like this
Then you remove the two bolts on the bottom
Then inside the back seat you pull the panel down and there is the top nut for the strut
You dont have to hold the bottom cause its flat and it will keep the shaft from spinning .
There is a left and a right for the rear struts so make sure you put them on the correct side
If you have coil over like me then you have to remove the flat piece on top the strut
By using a drill dont drill to deep
Tap it with a hammer till it comes off
You have to cut a little piece off that way you dont have to take the brake line apart and bleed your rear brakes
Then you put the clip back
And there you have it a new strut ....
Old 10-31-2009, 05:56 PM   #3 (permalink)
I want to improve my car!
View abrown0809's Photo Gallery
Hey man, what exactly was happening to your rear tires? I have a problem where the inside of my rear tires wore out to the point where its bare. Got my tires replaced, then it happened again within 5 months. And I got the wheels aligned before I got the new tires. I heard that the struts could be bad but I just want to make sure. I drive a 96 Corolla.
abrown0809 is offline   Reply With Quote
Old 11-01-2009, 05:39 AM   #4 (permalink)
WHat you just describe is what happen to me ... Yes you are gonna need knew struts
Old 11-01-2009, 08:55 AM   #5 (permalink)
Oh ok, thanks. Is there a certain brand I should get?
Old 11-01-2009, 10:50 AM   #6 (permalink)
Crash Tested
View Danimal7's Photo Gallery
I don't suggest getting parts like that from autozone. Got 2 rear Gabriel Ultras from there myself and ended up replacing them within 2 months. They're cheap but have lifetime warranty, so AutozoNe will keep giving you new parts but you have to mess with labor everytime.
Spend an extra 40 bucks and get some KYB GR2 struts from Rockauto.com
I replaced all four corners and it cost me 320 with S&H for the parts. Don't forget to replace the upper strut mounts as well, that's another 30-40 dollar part but vital to keeping your strut out of the interior compartment if you nail a bump if you know what I mean.
If everything is under control,
you're just not driving fast enough!
'99 Corolla LE 1.8L 1794cc [1ZZFE]
Danimal7 is offline   Reply With Quote
Old 11-01-2009, 11:15 AM   #7 (permalink)
on full afterburner
Gameroom cash: $1345597
Great posts!
I copied them to the Stickied FAQ just in case other members might want to refer to them in the future.
Old 11-01-2009, 11:48 AM   #8 (permalink)
Originally Posted by PhatRoyale View Post
Great posts!
No Problem thanks ...
To be honest with you everyone has a different experience with the same items . I have never had a problem with Gabriel shocks , For someone to spend $320 and another $40 on a car that is only used as a Daily Driver is crazy . You just have to learn how to drive , I dont beat on my cars , I keep them in a garage , I watch out for pot holes , Yes I do take them to the track every once and a while but other then that it gets me to work and they look clean . But if you have the money then go for it . But you cant beat life time .
Old 11-01-2009, 04:15 PM   #9 (permalink)
Crash Tested
It sure is a daily...
After the factory struts crapped out I had Gabriels on the front and then did the back, too. As soon as I got the rears replaced they went out, I'm leaning more towards a defective item. So, when I decided to replace them with GR-2's I went ahead and replaced all 4 corners. Autozone gave me a full refund for all 4 Gabriels (which cost $316 without tax, check their website).
KYB GR-2 struts are OEM replacement. These aren't your top of the line performance struts, but after riding on Autozone struts for a couple of months (the front ones were good, as opposed to the rear), I noticed a big difference in handling, going over speed bumps, ride quality, and even cornering. And to do the math correctly, at Rockauto.com I got all 4 KYB GR-2 struts for $306+$20S&H(maximum)=$326 not including tax.
So if you know how to drive, you assure yourself with lifetime warranty as opposed to the manufacturer saying that.
When you were replacing the speakers, did you use a special tool to get the rivets out? Or did you chisel them off and buy some replacements and install them?
Old 11-01-2009, 04:22 PM   #10 (permalink)
Crash Tested
The biggest pain with replacing the rear struts, was having to get around that closed clip. The front struts have an open clip. Had to disconnect the brake line and then bleed the brakes. I have also thought about using a zip tie to get the brake line to attach to the strut piece, but decided to just go ahead and do it right.
Old 11-01-2009, 06:15 PM   #11 (permalink)
This was so much easier when I cut the piece out and it still clips on and holds the line ...
I'm not disproving you about the struts , I guess because I get a 20% discount on my parts I see it differently , Plus its so much easier to run down to the local Auto Parts store then try to find KYB for replacements .... But moving on from that topic , As you see I used a Scraper I had or anything flat will snap it cause there Rivets are plastic ones and I replaced it with metal Rivets .... Its real simple , you need help just let me know I will help ya
Old 11-01-2009, 06:57 PM   #12 (permalink)
View CJCride's Photo Gallery
Canada
Nicely done Rincon & a double header at that.
Do you think that riveting the speaker to the original speaker bracket might be an idea. I plan replacing mine with a Pioneer set also.
Was the sound significantly improved?
CJCride is offline   Reply With Quote
Old 11-01-2009, 06:59 PM   #13 (permalink)
on full afterburner
Any aftermarket speaker will offer a sound quality upgrade over the crappy stock speakers, assuming that you have already done a headunit upgrade to something better.
Old 11-01-2009, 07:29 PM   #14 (permalink)
Thanks Phat, had the Pioneers for a bit, think I'll get them before it gets too cold.
Old 11-01-2009, 08:21 PM   #15 (permalink)
Crash Tested
I replaced them last winter with some Polk Audio speakers and didn't use the factory set up. Just took a few more drilling holes...but I have always wondered if there was some special tool that you put inside the rivet's hole to bang it out or something similar to that effect.
