P0171 system too lean bank 1 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2009, 12:45 PM   #1 (permalink)
View corollave's Photo Gallery
hey i recently pulled this code on my corolla i took to the dealer and they said that my mass air flow sensor was bad and i had it replaced. Well just the other day the engine light came on again and the same p0171 code came up. Was just wondering what to check next. Thanks
corollave is offline   Reply With Quote
Old 11-01-2009, 01:18 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
did you or did you not replace the sensor? its not clear there. things besides the MAF can cause that code. an air leak after the MAF, an exhaust leak, or a bad oxygen sensor are also common causes.
Old 11-01-2009, 01:53 PM   #3 (permalink)
Crowbar911's Avatar
View Crowbar911's Photo Gallery
i have been getting that code recently.
I cleaned my MAF (which was filthy from air filter oil after 80K), and reset the code.
I then got it 2K miles later, which I reset. then 200 miles later and I reset, and I have not gotten it back yet.(3K miles).
Im not sure whats up with that. try resetting it yourself and see if it comes back. (you can reset by pulling the neg cable to the battery for 5 - 10 mins)
SCCA First Place 10/25/09. NST
Crowbar911 is offline   Reply With Quote
Old 11-01-2009, 08:45 PM   #4 (permalink)
View msrdude's Photo Gallery
How many miles are on the car??? If its over 100k miles, i would replace the o2 sensor anyways. Im guessing its the o2 sensor; quite expensive, but got to be replaced sooner or later anyways.
Cars that I own:
1996 Toyota Corolla DX
1996 Toyota Camry LE
2007 Toyota Camry SE
msrdude is offline   Reply With Quote
Old 11-01-2009, 09:12 PM   #5 (permalink)
Toyota Tech in training!
View Downhillzze110's Photo Gallery
are you getting a misfire or is the car running rough? if not then you're probably not running lean, which would indicate bad precat O2.
a bad O2 sensor tends to flip lean codes then cause the EMU to err on the side of rich.
indicators of a bad O2 include bad gas mileage, black smoke from the tailpipe, hesitation off the line picking up at higher end. also pull your spark plugs and post pics of what they look like. i'll do a diagnosis from there.
this is what i'm studying this semester at school so some red lights are going off.
looking at your plugs will be a BIG tell. (its what professional race techs look at to diagnose race motors)
before you ask a 'how do i...' question answer this for me. do you own a repair manual for it? have you searched the forum for a similar issue?
SEARCH THE FORUM BEFORE YOU POST!
Downhillzze110 is offline   Reply With Quote
Old 11-03-2009, 06:25 AM   #6 (permalink)
View dorman68's Photo Gallery
A vacuum leak from a crack pcv hose, vacuum hose or leaky intake manifold gasket could cause this. Another likely culprit could be partially clogged fuel filter or injectors. My wife's Chevy had a lean code, the mechanic tried the mass air flow sensor, plugs, fuel filter and it ended up being partially clogged injectors, he performed an injector cleaning service and all is well. Hope this helps you out
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 11-16-2009, 11:33 PM   #7 (permalink)
just wondering where i might find the vacuum hoses?
Old 11-19-2009, 01:26 PM   #8 (permalink)
Gearhead
Gameroom cash: $196215
Vacuum hoses run all over the engine - you can't miss them. The trick is to find the bad vacuum hoses. Visual inspection can catch the majority of them, others, you need to get creative. There is vacuum diagram on the underside of your hood - a good idea to see if all the hoses are present. I could see a tech forgetting to put back a hose after doing some diagnostic work on the car.
Old 11-19-2009, 08:01 PM   #9 (permalink)
Woodyg's Avatar
Gameroom cash: $138765
View Woodyg's Photo Gallery
you can check for vacuum leaks by spraying carb cleaner all around. if you hear the engine rev there is a leak there. A code 171 suggest a maf issue, a vacumm leak issue or a fuel delivery issue. run some techron in it, clean the maf and check for leaks if that does not work change the fuel filter and do a fuel presure test.
Woodyg is offline   Reply With Quote
Old 11-20-2009, 10:08 AM   #10 (permalink)
have you checked your spark plugs? first thing you do if your getting a lean code is check vacuum hoses then spark plugs. if your spark plugs show signs of lean firing then you have a intake leak. also when you pulled the codes did you get any P030X codes (misfire)? those will be a BIG tell if you have a manifold vacuum leak or a dirty MAF
Old 10-16-2011, 09:15 AM   #11 (permalink)
View rdman7777's Photo Gallery
fixed my P0171 "Left bank running lean" code reading
I got the code P0171 recently and searched several forums for the definition and solution. Well, it seems that there are several possible causes, so I started with the cheapest solution first, cleaning the MAF sensor located in the large, curved, 3 1/2"-4" black rubber hose located to the right of the engine. I bought some MAF cleaner, sprayed it real good, gently used a q-tip around the resistor, put it all back together and so far, 100 miles later, the light is still out. The engine seems to be running smoother to. I would probably replaced the intake gasket next if that didn't work. Good Luck
rdman7777 is offline   Reply With Quote
Old 10-16-2011, 09:53 AM   #12 (permalink)
Woodyg's Avatar
you should create a signature for your car. include as many details as you can, engine, year, etc. my 98 does not have a MAF.
2006 Vibe, White, 1zzfe, auto ( Toyota type IV), AWD, PW, PL, CC, AC, 161,000(5/12/2012)
1998 Camry LE, 4 door, Puke Green, I4(5S-FE), CA Emissions, Auto(A140E), 122k(3/22/2012), AC,CC, ABS, Built in Japan 04/98. Grandmas old car(acquired 7/22/2011), work= precat Denso A/F sensor, NGK wires.
Old 12-19-2011, 08:59 PM   #13 (permalink)
View empirefalls's Photo Gallery
my turn on P0171 Fuel System Too Lean - Bank 1
Every cold weather season,the code occurs with cold weather.
The code goes away after a couple of days, Comes back again,then goes away. Then its spring time. This has gone on for 2 yaars.
Its cold again, the code came on 3 days ago, it went out today. I fiqure this year i might try to solve it. It did not happen during the first tens of thousands of miles when the car was new, i am thinking some parts need to be replaced with new parts.
To begin with aMAP sensor, does my 2005 Corrola have one?
empirefalls is offline   Reply With Quote
Old 12-20-2011, 06:17 AM   #14 (permalink)
Woodyg's Avatar
you have a MAF sensor.......read the thread from the top.plenty of info in there for you....do you have an aftermarket airfilter or a cold air intake.....
Old 12-20-2011, 06:52 AM   #15 (permalink)
As in a Fram air filter? Yes. Clean, i replace 2x ayear
"cold air intake." Original
All sensors are original. I have no aftermarket parts. Spark plugs changed 2 years ago with manufacturer recommendation.
I just realized, the fuel filter is orginal and never changed
I miss living in Bos
2005 Toyota Collora
110000plus miles
recalled ECM only major issue so far
Hankook tires model 727
best tires ever ...2 tires at
9/32 tread after 43000 miles
other two 7/32.
Perfectly engineered tires
--excellent ride..good on snow
lower priced than walmart's cheap brand tires
