Sounds like the OP is inferring if it OK to wire it up by hand, "literally". Strip some wires from a harness to the radio harness and twist them together and use wire nuts or electrical tape.
I would recommend soldering those unions and using some shrink tubing. The end job will look much cleaner and there will be less of a likelyhood that something will come off (vibration) and short across something important - read "expensive".
Like The ///Man mentioned - don't make more work for yourself later with possible intermittent electrical bugs - spend some time now, equals less time later.
