Not sure exactly what you are getting at. Braking system on the cars can get pretty complex, if you look far enough into them.
If you are looking for a "piece or part" count, then you are correct. Typical 8th gen Corollas (1998-2002) in the North American market are a DISC/DRUM brake setup.
The "wear" items on the front DISC brakes are two rotor (one each side) and a set of pads for each rotor (inner and outer pad for each rotor) - total of 4 pads, 2 rotors.
The "wear" items on the rear DRUM brakes are two drums (one each side) and a set of shoes for each drum (leading and trailing shoe for each drum) - total of 4 shoes, and 2 drums.
