brake issues - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-03-2009, 06:18 PM   #1 (permalink)
Evil
View evil's Photo Gallery
Canada brake issues
Hello all!!
I am driving a 2002 corolla 170K almost on it i replaced the front brakes about 10000K back but didnot lubricate the brake lines or anything just made sure the master cylinder isfull do i need to do anything else when i replace my brake pads??
evil is offline   Reply With Quote
Old 11-03-2009, 06:48 PM   #2 (permalink)
View The ///Man's Photo Gallery
Not sure I understand your question, but fluid should be changed out at some point in 170k. If it hasn't, probably a good idea to. If the fluid isn't very clear, that is a good indicator that it needs to be changed.
The ///Man is offline   Reply With Quote
Old 11-04-2009, 12:13 PM   #3 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
You should lube the 2 pins/bolts that the caliper slides on with lithium grease. Probably not that big a deal if you noticed they were already pretty greasy. Other than that I concur the brake fluid should be bled out and replaced every 60,000 miles or so approximatley.
Chris Corolla S is offline   Reply With Quote
