Tire Size for 1998 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-04-2009, 03:07 PM   #1 (permalink)
View Richardman's Photo Gallery
Canada Tire Size for 1998 Corolla
1998 Corolla VE
I am going to replace the front two tires and want to know if the following sizes will work without rubbing. I do not care if the speedo will be off by a bit just want to know if it will fit properly.
1st tire P175 / 70R 14 Michelin Energy MVX4
2nd tire P195 / 65R 14 Michelin Energy MVX 4
Stock sizes are 175 65 14 or 185 65 14 depending what year your 8th gen is.
Please let me know thanks,
Richardman is offline   Reply With Quote
Old 11-04-2009, 09:14 PM   #2 (permalink)
DjiNN's Avatar
View DjiNN's Photo Gallery
you are staggering the tires?! My corolla stock tires are 185/65/14. If you want to use 195 use 195/60/14. I've tried 195/65/14 and i've had rubbing issues.
Subaru Impreza 2.5i Premium Satin White
DjiNN is offline   Reply With Quote
Old 11-04-2009, 09:55 PM   #3 (permalink)
Crowbar911's Avatar
View Crowbar911's Photo Gallery
id stick with 185/65-14.
The next time I get tires, im going to go a step wider to 195/60-14 for some added cornering. Every little bit helps
SCCA First Place 10/25/09. NST
Crowbar911 is offline   Reply With Quote
Old 11-04-2009, 10:24 PM   #4 (permalink)
Canada
Yeah I should stay away from the 195 65 14. Do you think the 175 70 14 will be a good fit? I am buying used tires off craigslist and sizes will vary.
