diagnostic port - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-05-2009, 03:53 PM   #1 (permalink)
Crowbar911's Avatar
View Crowbar911's Photo Gallery
diagnostic port
What is the diagnostic port in the engine bay for?
I always assumed it was for OBDII readings in the engine bay for ease of access, But I just got a scan gauge, and it's not even close to the plug under the dash.
Its to the bottom left of number 8, and right above the air filter box.
Sorry for using toyotafan113 pic
SCCA First Place 10/25/09. NST
Crowbar911 is offline   Reply With Quote
Old 11-05-2009, 04:22 PM   #2 (permalink)
Gearhead
Gameroom cash: $196215
It is used as an easy access diagnostic port - also referred to as DLC1. The one on the inside of the cabin is known as a DCL3 connector and designed for a scanner. Both give you diagnostic information, but in different manner. Example, you can use the DLC1 under-hood diagnostic port to query the ABS system or SRS system on the car, if you see one of their trouble lamps light up.
The DLC1 output is a unidirectional, low baud rate serial data stream - still can be used in cars that have DLC2 and DLC3 ports. Generally, you have to make use of a "short" pins (a cable that jumpers two of the pins in the connector port), to access the onboard diagnostics.
The DLC3 output is a bidirection, high speed/high baud rate serial data stream. Carries much more information at a much faster transmission rate.
