Radio problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-05-2009, 09:20 PM   #1 (permalink)
C0R011A's Avatar
View C0R011A's Photo Gallery
Radio problem
ever since i put leds behind my hvac and cluster i cant get a single clear radio channel....it has to do with the lights b/c iv erun experiments while i was driving. when i turn the interior lights off my radio id perfect, but once they turn on, even dimmed, i get a crackly annoying schreech and no channels work. also the acceleration of the car can be heard as a high pitches whine on the AM channels with the lights on which was a pretty funny experience as i was driving
any help besides taking the bulbs out or driving in the dark would be helpful
C0R011A is offline   Reply With Quote
Old 11-05-2009, 09:39 PM   #2 (permalink)
Crowbar911's Avatar
View Crowbar911's Photo Gallery
How did you wire the LED's?
are they running off power from the radio?
Could be electrical interference.
SCCA First Place 10/25/09. NST
Crowbar911 is offline   Reply With Quote
Old 11-05-2009, 09:44 PM   #3 (permalink)
heartdisease's Avatar
Gameroom cash: $113870
View heartdisease's Photo Gallery
Try a ground loop isolator on the new circuit?
heartdisease is offline   Reply With Quote
Old 11-06-2009, 03:49 PM   #4 (permalink)
Big T Dizzle fo Rizzle
BigTDogg (MA)'s Avatar
View BigTDogg (MA)'s Photo Gallery
You have a bad ground which is making the noise on AM. What circuit did you wire the LEDs into?/
My Vehicles:
2001 Toyota Corolla LE - EBC Ultimax Rotors, HPS pads, Goodridge stainless lines, K&N drop in filter, Magnaflow cat and Exhaust, KYB GR-2, Tein H-Techs
1990 Nissan 300ZX Twin Turbo - More mods than Lindsay Lohan has freckles
BigTDogg (MA) is offline   Reply With Quote
Old 11-06-2009, 09:27 PM   #5 (permalink)
C0R011A's Avatar
all i did was buy some led bulbs and replaced the stock ones
Old 11-07-2009, 01:42 AM   #6 (permalink)
ロンリードライバー
Gameroom cash: $224935
View all2baka's Photo Gallery
Buy from where?
all2baka is offline   Reply With Quote
Old 11-07-2009, 12:42 PM   #7 (permalink)
C0R011A's Avatar
superbrightleds.com
Old 11-10-2009, 10:12 PM   #8 (permalink)
C0R011A's Avatar
nothing?
Old 11-11-2009, 10:58 AM   #9 (permalink)
Gearhead
Gameroom cash: $196215
^^^ What did you check so far? Can't help unless you do some diagnostic work first. The above comments on ground loops is the most common issue here.
Need to grab a multimeter and start checking for ground loops (set multimeter to millivolt scale, touch two suspect ground points, should read zero volts, if there are some finite about of potential - you've found a ground loop - continuity check would also work, but not as sensitive).
Could also be a bad LED - try replacing them with standard bulbs and see if the noise goes away. If it does - you could have either bad, noisy LEDs and/or they are the wrong impedance and drawing much more juice than they are supposed to (could damage wiring, PCB traces, put too much of a strain on your charging system).
Could also be something completely unrelated to the bulbs. Could have a bad alternator or the battery is on its way out. Have those checked out and double check the chassis/engine ground points under the hood (just follow the wiring) - make sure the connection point is clean and dry.
As with any electrical work - make sure to disconnect the battery before you start unplugging wiring.
