Rattling on acceleration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2009, 11:01 AM   #1 (permalink)
Gameroom cash: $371570
View ilovecorollale's Photo Gallery
Another question that i've got no bit clue of.
Whenever i step on the gas to accel or into reverse...and i step the pedal nicely and slowly so it moves slowly with th rpm rising slowly too and why is that there is a rattling noise like something isn't tighten enough and sometimes i feel like its coming from the front of the engine or somewhere in the rear?Or is it that all 98-02 corolla have that noisy sound when accelerating?
What i thought was that it was maybe the muffler or pipe below rattling or so?
ilovecorollale is offline   Reply With Quote
Old 11-13-2009, 11:21 AM   #2 (permalink)
Gearhead
Gameroom cash: $196215
Could be an exhaust leak from one of the exhaust donuts that seal separate sections of the exhaust system. Check the joints between the exhaust components, see if you note any carbon deposits. Pretty common to have those donuts be almost completely disintegrated on this generation. Just from normal movement in the drivetrain and from just age.
Old 11-13-2009, 11:25 AM   #3 (permalink)
Oh ok...i'll give it a check later on then...anything else u can add for more help?
Old 11-13-2009, 07:22 PM   #4 (permalink)
NoLa Rolla
gaj1967's Avatar
View gaj1967's Photo Gallery
A common problem is the belt tensioner wearing out (shock looking thing goes bad). It usually sounds like a rumble, grungle marbly sound when you first hit the gas. Ok, I made some words up but that's what it sounds like. After it's up in RPM's you don't hear it.
Prices range from $50-150 depending on where you get. For a photo go to Rockauto.com and check for your year. It's listed under BELT DRIVE then BELT TENSIONER
Changing isn't that hard. Remove belt, remove a bolt or two (one is VERY long), put on new one, replace belt. It's probably a good time to put a new belt on while you have it off.
If I had a video camera and the money to replace the one on my girlfriends 99 I would record and post the process but I don't. lol
I don't think it'll cause any problems if you don't replace it, just might cut gas mileage and power down a little.
Gil
Did you search, here and on the internet, for your answer first? Chances are it was answered recently.
Re-read your post before submitting. Does it make sense to you?
Don't expect a response in two seconds. Nobody is getting paid for this.
gaj1967 is offline   Reply With Quote
The Following User Says Thank You to gaj1967 For This Useful Post:
lr34x4 (12-10-2011)
Old 12-05-2009, 10:35 AM   #5 (permalink)
View alfaffa's Photo Gallery
Gil
Is it the tensioner for the timming belt that needs to be replaced?
alfaffa is offline   Reply With Quote
Old 12-05-2009, 10:46 AM   #6 (permalink)
But this thread isn't talking about the belt or so...it's more like the exhaust system.
There's another thread elsewhere about belt and the tensioner.
Sorry but i'm not trying to be rude or disrespectful or anything but just letting it out.
Old 12-05-2009, 12:19 PM   #7 (permalink)
NoLa Rolla
gaj1967's Avatar
You originally said you had a rattle somewhere. You thought it could be exhaust related. I mentioned that sometimes owners hear a noise and sometimes think it's exhaust. You might be spending months trying to find the exhaust noise and it might end up being the tensioner. I'm just trying to be helpful by saying that.
And whenever I get a hold of a decent video camera and some bucks to change my girlfriends tensioner I'm going to record it and post it.
alfaffa - what I'm talking about has nothing to do with the timing. Timing is internal. Tensioner and belt are external.
Gil
Old 12-05-2009, 01:15 PM   #8 (permalink)
ilovecorollale - Sorry, but my car seems to have the same symptons, but the exaust system is just fine
gaj1967 - Ok, im just asking becuase i also got i rattling sound in my car, and i still havent been able to locate the rattling. But it sounds like its comming from the right side of the engine some where, and also it raises with the rpm.
Is there any way to make sure that the tensioner is actualy bad before i take it all appart?
Old 12-05-2009, 01:23 PM   #9 (permalink)
NoLa Rolla
gaj1967's Avatar
Someone can correct me if I'm wrong but I think you can remove the belt and run the engine for a minute to see if the noise remains.
I found out the problem by opening the hood, running the engine and revving it by hand while listening for the sound. Decent ears can locate the sound source.
You might also be able to see the tensioner bouncing a lot.
Gil
Old 12-09-2011, 11:57 AM   #10 (permalink)
enoel's Avatar
View enoel's Photo Gallery
I just replaced my belt tensioner, problem not solved; the rattling-vibration still there!
I also replaced the worn motor mounts...
What it could be?
enoel is offline   Reply With Quote
Old 12-12-2011, 10:01 PM   #11 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291852
View gold94corolla's Photo Gallery
Originally Posted by enoel View Post
What it could be?
Time for a new car?
gold94corolla is offline   Reply With Quote
Old 12-12-2011, 10:34 PM   #12 (permalink)
FSAE "Engine guy"
View Vlad1024's Photo Gallery
What it could be?
Could be anything. See if you can get it to rattle while parked so you can poke around looking for it.
08 tC mt
Smooth driving is comfortable and easy. It is also FAST(though not comfortable at speed). I don't care if you apex corners(everyone does) on a public road unless you suck at it(everyone). Hold a proper line or get out of my way.
Vlad1024 is offline   Reply With Quote
Old 12-13-2011, 12:56 AM   #13 (permalink)
enoel's Avatar
Thanks for the reply,
gold94corolla
No way, I just can't let my ''baby'' go!!!
Vlad1024
With the car parked (the car iddles ''perfect'') I only can get the vibration-noise while giving gas and depressing the pedal, then goes away at higher rpms; it sounds like a ''vaccum leak'' coming from the engine by the firewall. I have noticed some oil spots by the VALVE COVER, so I'm suspecting a bad VALVE COVER GASKET?
The rattling noise only occurs while upgoing a hill or driving in low gears.
Old 12-13-2011, 04:03 AM   #14 (permalink)
leakyseals's Avatar
Gameroom cash: $167700
View leakyseals's Photo Gallery
Rattle, tick and vibration can mean different things. A rattle/knocking sound can mean a bearing somewhere, a tick can be something with the vvt. A vibration that shakes the interior with no engine noise can be a motor mount. Without a video its hard to diagnose over the internet. Is the noise near the serp belt? middle of engine? What type/weight oil are you using?
leakyseals is offline   Reply With Quote
Old 12-14-2011, 12:14 AM   #15 (permalink)
enoel's Avatar
I found this video on youtube, the diference is I only get the rattle sound GOING UP A HILL or in low gears, for example: when accelerating entering the freeway, then the noise goes at 55-60mph...
The ''vibration noise'' seen to come from middle of the engine close to the firewall, exactly betwen valve cover and exhaust manifold (wich I also replaced exhaust flange gasket and bolt/spring).
I'm using Castrol GTX High Mileage, SAE 5W-30 and 5W-40; I mix them
My Corolla is a 2000 VE.
Thanks
