Clock, Radio and Lighter Fuse - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-14-2009, 01:44 AM   #1 (permalink)
Weekend Warrior
View 99UTCarolla's Photo Gallery
USA Clock, Radio and Lighter Fuse
I recently had to replace the fuse on the circuit that controls the clock, radio and cigarette lighter in my '99 Corolla. I had some difficulty finding the panel and correct fuse, so I thought I would post my experience so others won't have to waste any time.
First remove the nut holding the panel to the left of the pedals
With that panel out of the way, remove the two bolts holding the panel directly below the steering wheel. Pulling from the bottom, lower this panel, it will remain attached via the cable for the hood release, but will drop far enough to expose the fuse panel.
Next locate the desired fuse in the schematic on the panel. If the fuse you are looking for is on the bottom right of the schematic, it will be on the bottom right of the panel.
Replace the blown fuse and put it all back together. It shouldn't take more than 10 minutes.
99UTCarolla is offline   Reply With Quote
Old 11-14-2009, 10:26 AM   #2 (permalink)
View jay0016's Photo Gallery
Were you going for the fuses behind the little cubbi hole thing.
jay0016 is offline   Reply With Quote
