Cooling system flush - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-14-2009, 11:52 AM   #1 (permalink)
View Brad1's Photo Gallery
I'm preparing to change the coolant in my 2002 Corolla. It jus turned over 80,000 miles. I bought this car this past summer. It had 76,000 miles on it at the time. I have no way of knowing when (or if) the coolant was last changed.
Should I use a chemical when flushing the cooling system, or is plain water good enough for flushing?
I was planning to use distilled water (mixed with anti-freeze of course) when I fill the cooling system back up.
Please let me know what you think?
Thanks.
Brad1 is offline   Reply With Quote
Old 11-14-2009, 12:11 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
a drain and fill is fine, you can drain the block if you want from the block drain. its located on the back side of the engine.
Old 11-14-2009, 09:54 PM   #3 (permalink)
View msrdude's Photo Gallery
I say use water to drain it. And if you want, fill the car up with water, and drive it for about 5 to 10 miles.
Yeah, make sure it is a 50/50 mix and you are using the right kind of coolant.
You know how much coolant you need right?
Cars that I own:
1996 Toyota Corolla DX
1996 Toyota Camry LE
2007 Toyota Camry SE
msrdude is offline   Reply With Quote
