Originally Posted by Danimal7
Just curious, what pushed you toward that particular setup?
its the best of the oem parts. it would be all stock toyota parts sans the few parts, but would still give a bit more performance than a stock 98-02 1zz engine rebuild would.
also there are alot of differences between the celica and corolla 1zz. the head for the celica is milled for larger valves, the pistons also have larger oil drain holes and a slight dome in the center, the intake manifold has shorter runners and a larger plenum. along with a 60-65mm throttle body ( got to go remeasure mine), the mwr bearing are just waaay better than the oem aluminum bearings. the mwr will take more abuse, thus making the engine a bit more reliable. i would still run an oil cooler tho. oem toyota gaskets are just proven to be excellent. mwr valve stem seals because they are a better material than the oem ones. they seal better and will last longer. the celica also has a cast rod, where as the corolla actually got the better forged rod... figure that one out?
our 98-02 intake manifold uses 24.5in long runners. this to make the engine more efficent at breathing at lower rpm, about 1500rpm to be exact, which is good for fuel economy, but hurts performance. where as the shorter runners of the celica are tuned to be more sporty. they are more effiecent at a higher rpm. about 3500 if i remember correctly, its been a while since i did the math. the larger plenum also goes to increase proper air distribution amongst the cylinders and increase throttle response. better air distribution leads to less wasted fuel by one cylinder running slightly richer. our corollas also barely breath thru the tiny as hell 50mm throttle body. our head drastically out flows the tiny throttle body. this is why the engine seems to choke at higher rpm. combined with the restrictive intake manifold, and you have one engine that will not respond to any form of go fast modification.
the reason for the arp bolts, is toyota uses a factory stretch bolt. which means there use once and throw away. while this is good because it ensures that the head and what not receive the proper torque, its bad because the bolts stretch and should not be reused because they will not achieve the same load as before. nothing against toyota, but i dont like having to buy a 50+ dollar head bolt kit each time i tear an engine down. every 4a i ever rebuilt got studs. stock rebuild or not. its also the reason when you torque down a toyota head, the sequence is something like 23ft-lbs then 90* followed by another 90*.
