blacked out corners - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2009, 09:12 AM   #1 (permalink)
mital917's Avatar
View mital917's Photo Gallery
blacked out corners
has anyone tried to open the front corners to black them out i did my headlights but i cant seem to find a way to open the corners
mital917 is offline   Reply With Quote
Old 11-16-2009, 09:31 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Yeah, plastic lenses, you'll break them before you'll open them.
Old 11-16-2009, 01:35 PM   #3 (permalink)
mital917's Avatar
so theres no way to open them without breaking them rite?
Old 11-16-2009, 01:38 PM   #4 (permalink)
on full afterburner
Gameroom cash: $1345597
Bake them in the oven to loosen up the adhesive.
You can find detailed step by step instructions on google.
Old 11-16-2009, 01:39 PM   #5 (permalink)
mital917's Avatar
thanks guys for ur help
Old 11-17-2009, 04:09 AM   #6 (permalink)
Resident asshole
Flashmn's Avatar
Plastic lenses dont like being baked, works for the front lights, because the lens is glass.
Old 11-17-2009, 06:44 AM   #7 (permalink)
Gameroom cash: $120900
View Milky's Photo Gallery
uuh.. the head light lenses are plastic. it will work. just dont keep them in there for long. did it to a buddys altima (plastic lenses) a long time ago. i have used a heat gun too. on the low setting and just work your way around the lens, and be gentle.
Milky is online now   Reply With Quote
Old 11-17-2009, 08:19 AM   #8 (permalink)
mital917's Avatar
i already did my headlights just fine the corners look retarded because they r stock and i have a black car
Old 11-18-2009, 09:46 AM   #9 (permalink)
View Bhavesh's Photo Gallery
that is not correct
the adhesive used in sealing the lenses to the housing on the corners is different from the one used in the headlights. Heating up the corners in the oven will melt/damage the mounts before it melts the adhesive.
OP: AFAIK, your options are to:
-buy the full set with headlights on ebay ($135)
-put some overlays (black stickers) on your current corners
-find a way to carefully cut open the current corners (not with heat) to paint it
I know how you feel though...I also have a black car, and am considering the stock headlights becuase the corner markers stick out so much now
Bhavesh is offline   Reply With Quote
Old 11-18-2009, 12:29 PM   #10 (permalink)
Crash Tested
View Danimal7's Photo Gallery
I hit a trash can the other day and it popped right off, clean! Too bad i didn't notice it at the time to stop and pick it up.
Does anyone know where I can buy just the plastic cover or do i need to replace the whole corner assembly?
If everything is under control,
you're just not driving fast enough!
'99 Corolla LE 1.8L 1794cc [1ZZFE]
Danimal7 is offline   Reply With Quote
Old 11-18-2009, 02:20 PM   #11 (permalink)
View jay0016's Photo Gallery
Just buy a whole new corner only like 25 bucks on ebay if that, unless you want to try to reglue it i dont even know if thats possible lol or you can use clear packaging tape thats what i did lol doesnt look bad if you can get the tape to lay flat. I'm waiting for a pair of clear corners to come in so tape works for me.
jay0016 is offline   Reply With Quote
Old 11-22-2009, 09:18 AM   #12 (permalink)
stock corners or aftermarket?
maybe some slight heating, twisting, and gentle raps with a rubber mallet might be the way to take it off...
Old 11-22-2009, 12:29 PM   #13 (permalink)
Crash Tested
stock corners
Old 11-23-2009, 10:22 PM   #14 (permalink)
was the glue that remained thin, but brittle? do you think it can be cut with a dremmel?
Old 11-24-2009, 12:19 AM   #15 (permalink)
Crash Tested
I don't see any glue residue around it, it probably came off on fallen piece that has never been seen again. You can cut anything with a dremel tool, as long as you take the corner out and be careful with it. You can always remove the corner and look at it to match things up. Measure twice and cut once. If it doesn't look like you can get away with cutting it then don't. Not much more I can tell you, I just hit the trash can and got lucky.
