Mysterious belt or pulley noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2009, 07:15 PM   #1 (permalink)
View apillowofclouds's Photo Gallery
I have a 99 corolla, the cheapest model, no power windows etc. The car started about 6 months ago making a noise every now and then like a bearing chatter under the hood. It was very intermittent.
The noise suddenly got worse in the summertime one day when it was very hot, but it stopped at the end of the day. I managed to get the dealer to hear it and they said it was the tensioner pulley, which they replaced. A couple of days later I heard the same noise again, but then it stopped for about 6 months.
With the cold weather, the noise came back tenfold. It sounds like a whine like the power steering pump and an intermittent rattle like a really bad valve tap, and it is much worse when the car is hot. It happens while the car is sitting still and idlling. If I put slight tension on the steering wheel the noise stops completely.
I had the car back to the dealer again for diagnosis and they said this time it was the power steering pump. So, I had a good friend who has done major work on all kinds of cars help me out changing out the pump. That was yesterday. Today the noise is exactly the same as before we changed out the pump.
I am certain it is coming from the area near the power steering pump and idler pulley, and I had also changed out the alternator last year but the noise is definitely lower and farther back anyway, definitely not near the alternator.
Any ideas? I work with a bunch of guys who all work on cars a lot and one of them thought maybe a valve sticking in the steering assembly? Any hints are welcome!
apillowofclouds is offline   Reply With Quote
Old 11-16-2009, 07:52 PM   #2 (permalink)
Crowbar911's Avatar
View Crowbar911's Photo Gallery
Im not an expert on this by any means, but what about the belt itself being a problem? Is it original to the car? How many miles does the belt/car have on it?
SCCA First Place 10/25/09. NST
Crowbar911 is offline   Reply With Quote
Old 11-16-2009, 08:24 PM   #3 (permalink)
sorry should have specified - cars got 133k but belt was changed within last 15-20k and looks ok
Old 11-17-2009, 12:14 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Is the steering kinda stiff at times?
The Jedi Speeder at CarDomain
Old 11-17-2009, 05:20 PM   #5 (permalink)
Steering feels fine actually. I also bought an automotive stethoscope today and did my best to find the noise. It definitely still seems like the power steering pump but I don't understand how. It's exactly the same combination of whining and tapping but it's a new (or at least newly remanufactured) pump.
Old 11-17-2009, 05:26 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Hmm? I was thinking maybe the valve in your rack and pinion might be on it's way out. Don't kill me, but are you sure you have the proper fluid in it? Just trying to rule out what it isn't .
Old 11-17-2009, 05:28 PM   #7 (permalink)
Hey I'd be happy if the problem is bad fluid
I used autozone power steering fluid - I've been told the only cars where you need special fluid is Honda's. I would blame cruddy AZ fluid but it made the same noise before with the stock/OEM fluid (I never refilled it, the dealer may have topped it off)
Old 11-17-2009, 06:29 PM   #8 (permalink)
View pchalpin's Photo Gallery
Take a candle, and, with the engine running, bring the candle in contact with the each edge of the belt for a few seconds. If the candle wax eliminates the noise, replace the belt.
pchalpin is offline   Reply With Quote
Old 11-17-2009, 06:31 PM   #9 (permalink)
Toyota Tech in training!
View Downhillzze110's Photo Gallery
actually toyota power steering requires Dex II (III) trans fluid. not regular PS fluid. so the generic PS fluid may have done more harm then good
before you ask a 'how do i...' question answer this for me. do you own a repair manual for it? have you searched the forum for a similar issue?
SEARCH THE FORUM BEFORE YOU POST!
Downhillzze110 is offline   Reply With Quote
Old 11-17-2009, 08:14 PM   #10 (permalink)
Well, I went and checked the cap (can't believe we didn't look at the damn thing) and what do you know, Autozone was wrong (NOOOO SAY IT ISN'T SO) and, as you said, I should have used Dexron II.
Although I will definitely change out the fluid, it was making identical noises with the OEM fluid and pump so I suspect that's not causing the issue.
I read somewhere about a dirty filter in the resevoir causing aeration that makes noise, but my resevoir doesn't seem to have an obvious filter.
Old 11-17-2009, 08:15 PM   #11 (permalink)
The belt was changed fairly recently but I'll try it, I'll take any suggestion at this point. Thanks.
Old 11-17-2009, 09:39 PM   #12 (permalink)
View lee777's Photo Gallery
Could something be caught in one of the power steering hoses.
A partial blockage interfeering with power steering fluid flow, that
remained behind when pump was changed.
Did original pump have any broken vanes?
lee777 is offline   Reply With Quote
Old 11-19-2009, 08:07 PM   #13 (permalink)
Woodyg's Avatar
Gameroom cash: $138765
View Woodyg's Photo Gallery
where are the iacv on these things they make a whine when they are dirty bad
Woodyg is offline   Reply With Quote
Old 11-20-2009, 08:33 AM   #14 (permalink)
Is that the modern equivalent of a PCV? I'll look up where it is, at this point it's worth a shot.
I'm suspecting though after buying and using a mechanic's stethascope (a very cool tool) that it is possibly the valve on the high pressure line, which we didn't replace with the pump, perhaps that valve is not regulating pressure properly. I have to get the alldata diagram to make sure, I only saw the valve on a generic diagram of a steering pump, but mine does look like there is a valve on the high pressure line going into the pump.
Old 11-20-2009, 08:54 AM   #15 (permalink)
Woodyg's Avatar
The iacv is different from the pcv valve. You can clean the iacv just makes sure you use the recomended cleaner. I just mentioned it because the iacv can whine. But I doubt that is your issue it sounds ps relater the iacv should be on the throttle body
