Transmission Question
2002 Corollla S. Printed on the sticker in the driver's side door jamb is the following:
A/TM: - 01A/A245E
If my understanding is correct, the "A245E" indicates this car has the 4 speed automatic transmission. Is that correct?
I'm planning to change the transmission fluid and filter on the car this weekend.
One more question, with the 4 speed automatic, the differential fluid is not separate from the transmission fluid. In other words, when I change the transmission fluid, I will also be changing the differential fluid (supposing this car does indeed have the 4 speed automatic). Is that correct?
Thanks in advance.
Brad
