Leaks Everywhere! (lots of pics) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2009, 05:46 PM   #1 (permalink)
105
View 105's Photo Gallery
Well I see where at least some of my oil is going.
It looks like its leaking around the oil pan maybe. That doesn't seem to hard to fix but its also all wet up above there also.
Then its also leaking where the tranny meets the motor, and I found that piece of metal laying on that cross member along with some sludge.
tranny meets motor
1998 Toyota Corolla VE (A3 --> A4 swap completed 9-30-10)
105 is offline   Reply With Quote
Old 11-23-2009, 07:15 AM   #2 (permalink)
View dorman68's Photo Gallery
A common oil leak in the 1zzfe engines as they get older is the timing chain tensioner, there is an o-ring around the tensioner that gets brittle with age and starts to leak engine oil. I have helped a coulple of people with this repair, it's not too difficult.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 11-24-2009, 12:26 AM   #3 (permalink)
Crash Tested
View Danimal7's Photo Gallery
You must have taken pictures of my car. I had a leak from the valve cover gasket. And now i think i might have an unfixed leak either from the tensioner or the oil pump. Maybe the oil from the tensioner just ran down the oil pump to make it look oily. Oil pan gasket also leaks.
A good way to check is to wipe clean the places where you suspect an oil leak (i.e. gaskets, around the tensioner, gasket on the oil pan etc...), then drive around for a day or two and continually check the places you wiped to see if any fresh/clean oil has appeared there.
If everything is under control,
you're just not driving fast enough!
'99 Corolla LE 1.8L 1794cc [1ZZFE]
Danimal7 is offline   Reply With Quote
Old 11-24-2009, 07:58 AM   #4 (permalink)
105
Yeah I plan on doing that to check the oil pan and tensioner. What worries me is the leak coming from in between the tranny and motor and that mysterious piece of metal.
