Fuel Leak from the Line - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-23-2009, 02:32 AM   #1 (permalink)
Crash Tested
View Danimal7's Photo Gallery
"do not kink the fuel EPDM" is what it states on the rubber outing of the hard fuel line that runs to the injectiors...the line that goes right past the coil. I think it has been kinked although don't know it got kinked. The fuel is spuuing out when i start the engine. don't think any debri has gotten into it eventhough i have been running the car without the vacum line that connects to the stock air box for less than a day. is there a special procedure to remove this hard line?
working on the problem right now in the garage, any help is apreciated. if i get it before then i will post the answer. it sucks though cause i've been in the garaje working on droppping the suspension, replacing the lower control arms, and the rear motor mount all day. now everything is put together and the hard line(delivery line?) is leaking fuel hardcore.
thanks,
Dan.
If everything is under control,
you're just not driving fast enough!
'99 Corolla LE 1.8L 1794cc [1ZZFE]
Danimal7 is offline   Reply With Quote
Old 11-23-2009, 02:56 AM   #2 (permalink)
Crash Tested
just found out my hard fuel delivery line is corroded, it was fun to watch fuel spray out in a beautiful fountian when i cranked the engine on for a second and a half. trying to take the hard line off now, is there a quick disconnect system in place and if there is it definitely isn't all that quick. how does it work?
