'01 Glove box removal. Need help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-24-2009, 12:11 PM   #1 (permalink)
capblueberry's Avatar
View capblueberry's Photo Gallery
Ok was tryin to remove my glovebox to disable my DRL relay and i cant figure out how to get to the 10 mm. bolt on the right side near the passenger door.
i can see it but the kick plate is blocking it and cant seem to remove it easily and i really dont wanna break anything.
please help.
capblueberry is offline   Reply With Quote
Old 11-24-2009, 06:18 PM   #2 (permalink)
Gameroom cash: $371570
View ilovecorollale's Photo Gallery
Gotta use more strength to pull it out.It's clipped in with a metal piece thingy.
ilovecorollale is offline   Reply With Quote
Old 11-24-2009, 08:31 PM   #3 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295773
View Buurin's Photo Gallery
No.
Look at the kick plate. There should be a black plastic nut you have to unscrew (it's tricky, but it'll come out). Then you have to lift up the forward end of the scuff plate/running board - pry it up with your hand. Then it will come out.
Need M12x1.25 tap ASAP!
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 11-24-2009, 10:02 PM   #4 (permalink)
Originally Posted by Buurin View Post
No.
ok thanks so
1. unscrew plastic nut thingy and pop the plate off the bolt.
2. then lift up on the end where the plastic nut screwed on and sorta pull back towards me at the same time
that about right??...i messed with it alot today and it looked kinda like i was gonna have to remove the plastic runner along the bottom of the door jam, glad its just as simple as me not pulling hard enough ha.
thanks guys
