Vibration could come from a number of sources. Need a bit more information.
Vibration noticeable in the steering wheel or the whole car?
Who mounted and balanced the tires?
Do you know the specific machine they used to balance the tires?
How much weight did they put on each wheel in total (weight is stamped on the wheel weights themselves)?
Did they check for runout on the wheel (check for bent wheels)?
Did they check for runout on the hub (check for a bent or distorted hub)?
Have you tried to rotate the tires back to front and see if the vibration changes?
