head gasket - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-30-2009, 08:03 PM   #1 (permalink)
Gameroom cash: $371570
View ilovecorollale's Photo Gallery
head gasket
It seems that there are 2 gaskets there, correct?
How do you know when to change your gaskets?
Besides i can see lights coming in between those 2 gaskets and the headers too and yes i have tighten those bolts...i mean seeing the lights coming through would mean that air would leak through there from the engine and not fully airflow into the header pipe.
Sorry if i don't seem talk any sense but that's the best i can describe.
ilovecorollale is offline   Reply With Quote
Old 11-30-2009, 08:21 PM   #2 (permalink)
Toyota Tech in training!
View Downhillzze110's Photo Gallery
you have 1 head gasket. 1 intake manifold gasket. and one exhaust manifold gasket.
if you plan on replacing the head gasket then get those, a valve cover gasket, fuel injector O-Rings, and head bolts. a compression test and a cylinder leak down test will tell you for sure if you need a head gasket. unless you have a leak down tester and 100 psi or more of shop air only a certified technician can do this.
please do yourself and everyone else a favor and get a Haynes manual. that will explain how to do most basic mainainance and everything including tearing the car down to the frame (if you really wanted to)
before you ask a 'how do i...' question answer this for me. do you own a repair manual for it? have you searched the forum for a similar issue?
SEARCH THE FORUM BEFORE YOU POST!
Downhillzze110 is offline   Reply With Quote
Old 11-30-2009, 11:39 PM   #3 (permalink)
98 Corolla
old-corolla's Avatar
View old-corolla's Photo Gallery
i appreciate your blunt response
that manual will save you a lot of time
old-corolla is offline   Reply With Quote
