hvac light replacement on a 2000 corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-02-2009, 03:27 PM   #1 (permalink)
xpo148
View xpo148's Photo Gallery
i got a 2000 corolla and just change my instrument cluster light from the step by step instruction on this forum. I was wondering if anybody has a step by step process on how to change the lights on the hvac unit? I pulled out the ash tray cluster and the screws on the hvac unit, but no luck in locating where the lights are at?(and the hvac unit didn't pull out all the way) i search all over this forum to see if anybody posted how to change the lights.. please help..
xpo148 is offline   Reply With Quote
Old 12-02-2009, 06:46 PM   #2 (permalink)
View bpr288's Photo Gallery
i think i may have mentioned something a little somewhere around here about it, but when you take out those two screws on the side of the hvac (and probably lose them in the process like i did...they just automatically fall down into the abyss), youll take out the actual hvac boxy panel thing, with wires that limit how far you can take it out.
next, pull off the three ac nobs, and then really all you need to do is get a flat screwdriver, and pry the four little wedge things..two on top, two on bottom, which hold the hvac box together. i know it sounds weird but just look at it for a little bit and youll figure it out. the front colored grey or tan plastic panel will then be unclipped from the off-white housing, and youll just pull them apart.
the two LEDs will be right there in the corners, connected to the off-white housing. i had a little trouble putting in one of my blue hp74's but itll eventually just jiggle on into the bulb mount.
hope that helps!
bpr288 is offline   Reply With Quote
Old 12-02-2009, 07:05 PM   #3 (permalink)
ロンリードライバー
Gameroom cash: $224935
View all2baka's Photo Gallery
Try taking out your stereo, the two bulbs, one on each corner of th HVAC, just sit under the stereo
all2baka is offline   Reply With Quote
Old 12-02-2009, 08:37 PM   #4 (permalink)
View Dukeie's Photo Gallery
yes you don't have to remove the HAVC just take out the Stereo and presto there are the wire for the bulbs
Dukeie is offline   Reply With Quote
Old 12-02-2009, 09:33 PM   #5 (permalink)
im confused...but thats probably because ive never taken out the stereo. how can you get to the bulbs? do you just follow the wire to the hvac and pull out the housing from the back?
thats the only way im seeing this
Old 12-02-2009, 11:36 PM   #6 (permalink)
xpo148
thanks
thanks for the info... those technique will be useful..
Old 12-03-2009, 05:18 PM   #7 (permalink)
View jay0016's Photo Gallery
You can just twist out the two light bulb holder things look in the back of the HVAC and youll see two twist lock light holder things(can't think of the name now) turn like a half turn either way it budges and pull out then you can easily replace the bulbs
jay0016 is offline   Reply With Quote
Old 12-05-2009, 02:52 PM   #8 (permalink)
ahh right. id rather do it my way though..dont feel like unplugging wires and all that from the radio. plus ive never taken apart that area of the dashboard just yet...had someone else install the radio lol
thanks for the info though!
