Wrench issue with the belt tensioner removal
Case:
2 hexagonal bolts fix the belt tensioner to the engine. The one on the top, above the black cylinder, was easily moved.
The issue is with the lower one, and I am not getting confused with the releasing nut, which is above the tensioner's fixing bolt. I tried for 1 hour to remove this "main" belt tensioner bolt, and nothing worked. I tried WD-40 and some engine oil splotched with tissues to grease the surface and let it lubricate and penetrate the bolt space, but still it did not move.
After reassembly to a normal state, I got 2 choices:
1) try again with another wrench with longer leverage - but which one? I only have the basic, max 10-inch wrench, and prefer not to buy another tool just for this job.
2) go to Pepboys, or any auto shop to have it fixed, and expect an estimate of $100. Yes, I already have the OEM part, and only need a replacement labor cost.
Your thought? Thx.
