Power Steering Resevoir/Pump Hose Routing Help
I have a 99 CE and Im going to be flushing out my power steering fluid and I have some questions. According to the FSM it says to "Disconnect the power steering gear outlet hose from the reservoir". But I am unsure of which hose it is. Im pretty sure its the top hose on the reservoir (outlet from pump to reservoir). And that the bottom hose is the outlet from reservoir to pump. I just want to confirm that I am disconnecting the right hose to flush it out. So, am I right in guessing that the top hose on the reservoir is in fact the outlet hose from the pump, meaning the fluid return hose from the pump back into the reservoir?
