Do you know what pads they used? Most pads need some sort of bedding in process before they work correctly. Think of it as breaking in the pads on the rotors. If don't incorrectly, you'll probably have some weird braking behavior. I total agree with CJCride - take it back and have them recheck their work. If it checks out OK, ask for the proper bedding process - if none is specified, there are tons of example methods online. Just look up bedding in brake pads. Just keep in mind that if you got brand new pads and rotors - could take a little bit of driving before the car starts to behave normally (have to wear down the machining marks on the rotor).
