Air Conditioning not blowing cold air. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-08-2009, 06:22 PM   #1 (permalink)
View azncapcom's Photo Gallery
2000 corolla LE. The air conditioning is not blowing cold air. The A/C light is OFF. would this mean its just a minor problem like the a/c fluid? or could it also mean hundreds in repair?
azncapcom is offline   Reply With Quote
Old 12-09-2009, 11:32 AM   #2 (permalink)
Gearhead
Gameroom cash: $196215
Hard to say, without checking to see what the pressures are like and exactly what the system is doing.
As a safety feature, the compressor will not run if there is low to no charge on the system. So it could be as simple as recharging the A/C and you are good to go. The potential issue, what caused the A/C system to lose the refrigerant in the first place.
Depending on what happened to the system, could be a simple hose or connector replacement. If you have a hole in the condensor (in front of radiator) - easily looking at a couple of hundred dollars.
Old 02-27-2010, 06:41 PM   #3 (permalink)
View GaryGoatse's Photo Gallery
It could just be that the button is not working or it could be like fishexpo101 said. Check your area if you have an A/C specific shop you could take it to because not a lot of shops do A/C service where I am except the specialty ones. I recommend not doing anything yourself because refrigerant is dangerous stuff to be messing with (I over pressurized my system on my own and green oil and refrigerant shot everywhere)
good luck and be sure to tell us what you ended up doing =)
GaryGoatse is offline   Reply With Quote
Old 02-27-2010, 07:30 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
If your system has a sight glass, you might wanna take a look and see if there's freon in it.
The Jedi Speeder at CarDomain
Old 02-27-2010, 10:52 PM   #5 (permalink)
MOFO_HO
View white_trix-e's Photo Gallery
if u need any part hit me up! i have the compressor, hoese, even the control unit on the dash!! i give great prices and ship same day
white_trix-e is offline   Reply With Quote
Old 02-28-2010, 11:33 AM   #6 (permalink)
View brooklyn99corolla's Photo Gallery
My A/C was blowing out warm air but my A/C light was blinking, changed the clutch relay and it was fixed for about $7.00. Got the relay used from ebay.
1999 Toyota Corolla CE
2005 Tahoe Z71 - 22" Liquid Metals-Western Ultimate
Bull W/PIAA 520-OEM NavW/6 Disc Changer - Every Available Option
2007 Infiniti QX56 - 22" Konig Rolf Blix - Every Available Option
brooklyn99corolla is offline   Reply With Quote
Old 03-02-2010, 08:09 PM   #7 (permalink)
if the compressor wont run because of low to no charge... wouldnt that affect my windshield defrosting? as far as i know, when defrosting it turns on the A/C automatically? The car doesnt seem to have any defrosting problems. Would that rule out the low charge?
