98-99 1zz-fe valve clearance adj - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2009, 10:10 AM   #1 (permalink)
Fergifruitchew's Avatar
View Fergifruitchew's Photo Gallery
I found out that on the non vvti 1zzfe if you remove the valve buckets you have to re adjust them...like match the right ones to the valves, heres how and this is straight out of the official toyota mechanics book:
You need a feeler guage to measure the distance between the top of the bucket and the bottom of the camshaft lobe, on intake side they must be 8 thou of an inch and 12 thou on exhaust side, any less is not good-goes for both sides.
Fergifruitchew is offline   Reply With Quote
Old 12-14-2009, 07:53 PM   #2 (permalink)
randini667's Avatar
View randini667's Photo Gallery
I kept my caps in the same place and grounded the valves tops down to meet the specs. I wasn't lucky enough to be able to switch them all around, ran out of the thicker ones.
randini667 is offline   Reply With Quote
Old 12-15-2009, 12:04 AM   #3 (permalink)
how did you grind the valve tops down? what did you measure with too, or did you measure?
Old 12-15-2009, 08:51 AM   #4 (permalink)
randini667's Avatar
It's in the first post here. There are some pics, but I had the cam in snug and dry fit the valves, using a feeler gauge to find the clearance. Then threw the valve in the mill. Mill, measure, re-check. Tedious work.
Old 12-15-2009, 12:16 PM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
The easiest thing to do is measure the clearance, then buy the proper size lifter. I just bought 16 1zz lifters. $12.06/ea
The Jedi Speeder at CarDomain
Old 12-15-2009, 12:21 PM   #6 (permalink)
im just going to get another complete head from picknpull, under 40 bucks and its already done, just needs to be cleaned
Old 12-15-2009, 12:25 PM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
You will still need to check valve clearance.
Why does the head need to be replaced?
Old 12-15-2009, 01:03 PM   #8 (permalink)
my harmonic balancer fell off while driving 2 blocks from my house on a very cold day lol.. bent all exhaust valves, i had 16 spare valves from the same engine but with VVTI, i found out that the valves are longer than mine and when i put the cams on all of my valves are open and i have no compression... im just going to get another head that matches my non vvti engine and ill be on my way.
Old 12-15-2009, 01:37 PM   #9 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Oh wow...
I do recommend you have the head checked out. Pressure tested, vated, new valve seals, check valve clearances and resurface.Maybe even a valve grind if neccessary.
Old 12-15-2009, 01:44 PM   #10 (permalink)
the head itself is fine, the only problem is, i have longer valves. The buckets i have match the valves(both valves and buckets came out of a VVTI 1zzfe) my head is a non vvti head which had shorter valve stems and different bucket sizes. im just going to get a head that matches, it will have valves, buckets and all that stuff already set up, all i have to do is drop it on my block and hook it up, put the cams on and start it up. It will be fine
