Originally Posted by DMC6453
Hi,
When I took my 98 corolla for emissions testing in california 4 years ago the Nitrous oxide was a bit high. When I took the car two years ago for emissions the NO was at the maximum allowable limit.
Nitrous oxide is N
2O.
You must have had high NO
x (NO and NO2) emissions. This may be caused in part by a too-lean fuel mixture.
The PCV valve can usually be cleaned with carb or throttle body cleaner--if it rattles when you shake it it's probably just fine for the most part, anyway.
