stock gear shift - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-15-2009, 06:01 AM   #1 (permalink)
View hondotony's Photo Gallery
stock gear shift
I have a automatic transmission and can't get the gear shift button to go in and release the shifter to go to drive.The button pushes in but does not engage to release the shaft handle to be move.How can I fix this?
hondotony is offline   Reply With Quote
Old 12-20-2009, 01:49 PM   #2 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295773
View Buurin's Photo Gallery
A number of things.
First check your brake light. If the brake light switch fail, this will happen.
Pop the plastic piece on top of "P" on the lever and press it. Can you now shift it off P?
Can you press the button all the way in or it just goes in a little and not any further?
Need M12x1.25 tap ASAP!
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 12-20-2009, 02:54 PM   #3 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291852
View gold94corolla's Photo Gallery
On mine, the button would stick, so like it would go in but then not come out. It suddenly started working again though.
gold94corolla is offline   Reply With Quote
