Timing Chain tensioner leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-16-2009, 12:43 PM   #1 (permalink)
View eaglered_77's Photo Gallery
USA Timing Chain tensioner leak
Ok, so I got hit with the Timing Chain tensioner leak problem on my '99 Corolla. So I'm guessing replacing the O-ring should fix it ?
- Anyone have a pic or guide as to where I would go looking for this ?
- Do I need to reset the tensioner afterwards ?
- What is a reasonable cost to get this done ?
eaglered_77 is offline   Reply With Quote
Old 12-16-2009, 06:42 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
replace the tensioner, new one comes with an o-ring. you need to pop the valve cover off to release the catch that holds the new tensioner compressed.
Old 12-17-2009, 01:20 AM   #3 (permalink)
View mr1114's Photo Gallery
When replacing it, do any other adjustments have to be made? Or is it a simple remove and replace?
2006 Corolla S - sold
2003 Solara SLE - sold
2000 Corolla LE - sold
mr1114 is offline   Reply With Quote
Old 12-17-2009, 06:24 PM   #4 (permalink)
randini667's Avatar
View randini667's Photo Gallery
This guide had all the information I needed when I replaced mine.
http://madstyle1972.com/Repair/14/201lbc04/a040001.pdf
randini667 is offline   Reply With Quote
Old 12-18-2009, 07:04 AM   #5 (permalink)
Gameroom cash: $201383
View teppista881's Photo Gallery
Randini,
When doing this procedure without adjusting valve clearances, do you see any reason to remove the serpentine belt tensioner as well? Seemed excessive from the writeup, but maybe it just clears out some space.
teppista881 is offline   Reply With Quote
Old 12-18-2009, 07:26 AM   #6 (permalink)
Bitter's Avatar
you pretty much just take the valve cover off, take the tensioner out, put the new one in, poke it with a screw driver to release it, and then put everything back together.
Old 12-18-2009, 08:08 AM   #7 (permalink)
randini667's Avatar
I believe the article is excessive. If I remember correctly, you can leave the serpentine tensioner alone, and still have room to work on the chain tensioner... As Bitter said.
-Randy
