Sri - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2009, 08:48 PM   #1 (permalink)
~Veer~'s Avatar
View ~Veer~'s Photo Gallery
Sri
So im looking to buy a SRI it says its made for a 2001 engine i have a 2000 corolla will it fit with no problem ???
INJEN SHORT RAM INTAKE: COROLLA S 1.8L 01-02
~Veer~ is offline   Reply With Quote
Old 12-20-2009, 08:49 PM   #2 (permalink)
~Veer~'s Avatar
Part#: IS2080P
sry forgot
Old 12-20-2009, 09:05 PM   #3 (permalink)
Crowbar911's Avatar
View Crowbar911's Photo Gallery
Should fit without a problem. same engine, same engine bay.
Wait,
Unless that was the near they changed from MAP to MAF. its a airflow sensor. Give me a moment to check my haynes.
SCCA First Place 10/25/09. NST
Crowbar911 is offline   Reply With Quote
Old 12-20-2009, 09:17 PM   #4 (permalink)
View CJCride's Photo Gallery
My 01 has a MAF
CJCride is offline   Reply With Quote
Old 12-20-2009, 10:21 PM   #5 (permalink)
Toyota Tech in training!
View Downhillzze110's Photo Gallery
PAY ATTENTION!!!
1ZZ-FE DIFFERENCES BETWEEN YEARS ARE AS FOLLOWS!
1998-1999: Ignition: waste spark twin coil pack. Valve timing: non-VVT-i. intake metering: Intake Air temperature and Manifold absolute. intake manifold: Pressure cast equal-runner aluminum
2000+: ignition: Sequential Coil-Over-Plug. Valve timing: intake camshaft VVT-i. Intake metering: Mass Air-Flow. Intake Manifold: depends, some have the 98-99 manifold, others have a black thermo-plastic intake manifold
this should probably be stickied...
before you ask a 'how do i...' question answer this for me. do you own a repair manual for it? have you searched the forum for a similar issue?
SEARCH THE FORUM BEFORE YOU POST!
Downhillzze110 is offline   Reply With Quote
Old 12-21-2009, 12:31 AM   #6 (permalink)
~Veer~'s Avatar
so is that a yes? i wasnt looking to get all technical
where would i find me a black thermo-plastic intake manifold...i got me a sh*ty 98-99 manifold
Old 12-21-2009, 12:36 AM   #7 (permalink)
the aluminum manifold looks better. i think the plastic manifold looks hideous. but thats just my opinion
and to answer your question. a SRI for an 00 will work on a 01.
Old 12-21-2009, 12:41 AM   #8 (permalink)
~Veer~'s Avatar
my god man thank you <3
Old 12-21-2009, 04:20 PM   #9 (permalink)
Bdub215's Avatar
Gameroom cash: $317265
View Bdub215's Photo Gallery
downhillzze110 are you sure the plastic intake came on our generation 1zz? i've never seen one. i thought that was 2003 1zz's up?
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 12-22-2009, 02:00 AM   #10 (permalink)
Gameroom cash: $120900
View Milky's Photo Gallery
they are 03+. and also on celica gt's in 2000. i have one swapped onto my engine. it man a huge difference on power. it has a larger plenum, and shorter fatter runners. it out flows the crappy aluminum one by leaps and bounds. and also allows you to run the 65mm celica gt throttle body. which is even nicer so you can use 3in piping on your intake. as seen below on my dirty daily driver. you can also purchase the manifolds from rock auto for just under 200 brand new, or watch ebay for one to pop up. make sure to get it with throttle body if you can. i also have a spare manifold, but its for drive by wire.
Milky is online now   Reply With Quote
Old 12-22-2009, 09:43 AM   #11 (permalink)
Old Fart
Salty_Dog's Avatar
Gameroom cash: $195865
View Salty_Dog's Photo Gallery
I have a Injen SRI I'll sell you cheap. PM me.
Salty Dog
Visit www.TundraSolutions.com
The Web's best site for all information about your Toyota Tundra
Corolla: http://www.cardomain.com/ride/2933753
Tundra: http://www.cardomain.com/ride/2515030
Salty_Dog is offline   Reply With Quote
Old 12-22-2009, 10:24 AM   #12 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295773
View Buurin's Photo Gallery
I read about someone swapping in a 03+ 1ZZ to our gen and have to retain the aluminum manifold for clearance. Does it mean the entire engine can be dropped in and still clears the bay? There's some talk about keeping the 8th gen exhaust manifold gives us more power tho.
Need M12x1.25 tap ASAP!
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 12-22-2009, 10:34 AM   #13 (permalink)
Gearhead
Gameroom cash: $196215
Have to match the intake characteristics to the powerband that you want to focus on. The longer aluminum intake runners and the OEM exhaust manifold matches the fatter torque curve on the 8th gen engines - which makes a good amount of torque off idle (meat of power band is in lower RPMs).
If you tend to run the engine out to redline constantly - then a shorter, wider intake manifold will make use of the better flow at higher RPMs. Of course, it is best to run an EMS system to take advantage of the higher flow.
The composite plenum of the 9th gen Corollas (2003+) was chosen to shift the power band upwards. It is complemented with a revised camshaft profile and ECM retuning as well - which swells the power band in the mid-range to upper RPMs.
Not sure what the exact numbers will work out to, if you run a 9th gen engine with an 8th gen intake and exhaust manifolds - but given that this swap has be done several times and no one seemed to have complained, I'm guessing they are not seeing much issues with power. If anything - the revised camshaft and tuning probably makes the car feel more powerful.
Old 12-22-2009, 01:09 PM   #14 (permalink)
on full afterburner
Gameroom cash: $1345597
I'm curious to see how much of a benefit there is in reality from doing the swap.
If anyone does decide to go through with it, then please post some before and after dyno charts to confirm any gains that may occur.
Old 12-23-2009, 10:06 AM   #15 (permalink)
i only listed differences in the 1ZZ-FE in general. and 2000 celicas have 1ZZs with black plastic manifold. it is true that no 8th gen came with the black plastic but there were 1ZZs manufactured in 2000 that have it
