excuse my ignorance, but what do you mean when you say "run a fresh connection from my ignition..."
are you looking for a +12 lead, that turns off when you turn off the car?
and when you say "never opened my ignition", do you mean cut into wires to find that +12 lead?
if so, there are already +12 leads in your car that will turn off with your car. If you're running heated seats that use 200W of power, you need find an existing wire in the car that is capable of supplying 17A of current (200W/12V=16.6A). 17A is not fuse size that's common, but 20A is. Check your fuse box to see if there are any unused connections with a 20A fuse, and tap into the fuse using this type of connector:
or
your alternative would be what crowbar already recommended: if you can't find a wire that will supply the 17A of current, you would need to a run a thick enough wire (with an inline fuse) between your battery directly to your heated seats. You can trigger it to turn off with the car using an
automotive relay.
here is an example of the wiring for the relay:
