projector retrofit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2010, 09:55 PM   #1 (permalink)
View SilverNitrate's Photo Gallery
projector retrofit
So has anyone done a projector retrofit on a 99 corolla before? I want to install a projector and use a true hid on the car. Does anyone know if there is a DIY anywhere out there for 99 corolla?
SilverNitrate is offline   Reply With Quote
Old 01-01-2010, 10:41 PM   #2 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291852
View gold94corolla's Photo Gallery
I HIGHLY recommend this website
http://www.hidplanet.com/forums/
The most recent 2002 Corolla retrofit done was by Buurin, who converted his 99 to an 02 and did a retrofit at the same time.
http://www.hidplanet.com/forums/view...hlight=corolla
A couple of pics from another person here
I have done a retro myself, and the results are unbelievably good. If you do it right, using true HID projectors, you will get output like this!
Also, check out this store for the best retrofitting products
http://store.theretrofitsource.com/
For your head lights, I would recommend using the FX-R projectors.... that's what I used, and they are the best for you.
http://store.theretrofitsource.com/p...e3a3bc27f16b65
Next, pic out some shrouds to cover up the projectors
http://store.theretrofitsource.com/i...e3a3bc27f16b65
That will finish your head light nicely after you mount and aim the projectors. Then you will need a d2s HID kit (bulbs, ballasts, wire harness) to light it up. You can use any ballasts, but I recommend true OEM Phillips 85122 bulbs because they have the best beam pattern.
DDM Tuning has the best HID kits for the price! You can also get 50~55 watt ballasts for even more light!
Hope this helps! Feel free to ask more qs.
gold94corolla is offline   Reply With Quote
Old 01-01-2010, 10:53 PM   #3 (permalink)
Would any of you guys be willing to retrofit one for me? I'm willing to pay. =)
Old 01-01-2010, 11:24 PM   #4 (permalink)
ah man, not me, I'm too exhausted after just finishing my head lights!!
Old 01-01-2010, 11:26 PM   #5 (permalink)
MacktasticSlick's Avatar
View MacktasticSlick's Photo Gallery
Originally Posted by hummerh2o View Post
Iv done a retrofit on a 99 and 2001, theres no DIY thyre way too tedious and time consuming. But the effort goes a long way and im happy with the end result
Does that mean that you still have the headlight housings for a 99 laying around that are already retro-fitted?
MacktasticSlick is offline   Reply With Quote
Old 01-03-2010, 02:11 AM   #6 (permalink)
ロンリードライバー
Gameroom cash: $224935
View all2baka's Photo Gallery
Are those 35w or 55w ballasts?
I'm looking at FX-R complete kit as a possibility for my eventual retrofit
all2baka is offline   Reply With Quote
Old 01-03-2010, 03:19 PM   #7 (permalink)
Hey,
Actually, mine is more like 70 watts .... because I have 2 35 watt ballasts and FX-R on each side!
It is unbelievably bright!! I love driving at night now, even just for fun
Old 01-03-2010, 04:12 PM   #8 (permalink)
ロンリードライバー
lol all right i'm getting 55w then
Old 01-03-2010, 04:20 PM   #9 (permalink)
yeah, do that, it is really nice..... only a few potential problems!
it says "55 watts" but it is almost always more like 50 or LESS
If you don't use philips OEM 82155 bulbs, there will be a ton of heat which will most likely damage the projectors
if you have a failure, it might cost more $$$ to replace a 55 watt ballast/bulb
good luck!
Old 01-03-2010, 11:43 PM   #10 (permalink)
ロンリードライバー
good luck!
ah ok, i'll have to think about it then, maybe go with 35w on the safe side. i'm looking at the fx-r complete kit with everything at the moment.
Old 01-04-2010, 07:48 PM   #11 (permalink)
the FX-R is my favorite (obviously) but it will take work to put in your head lights and get looking right.
www.HIDplanet.com is where to go to learn about retrofits!
Old 01-04-2010, 10:45 PM   #12 (permalink)
ロンリードライバー
i'm upgrading from a mod-express kit so not that much more work other than the retrofit. awesome, thanks. i've been wanting to hear more opinions from those who got the fx-r.
Old 01-05-2010, 02:22 AM   #13 (permalink)
View nuron's Photo Gallery
I'm looking into starting a retrofit on my '01 and was wondering what the cheapest projectors are to start this? I'm hearing Cadillac and E55 but the E55 are bi-xenon which I don't really need since I have a separate high beam...
nuron is offline   Reply With Quote
Old 01-05-2010, 10:56 AM   #14 (permalink)
Can you guys post pics of your retrofits and list the parts that you bought for your retrofit? Thanks so much!
Old 01-05-2010, 10:03 PM   #15 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295773
View Buurin's Photo Gallery
mod-express kit just stands in for whatever bulbs you're using. Sure you can keep the ballast but you still have to do the actual retrofit and buy the pair of AMP->D2S adapter.
I went bixenon (I did mine before the FX-R projector came out) and went the extra couple miles to mod the wiring so that I keep the high beam bulb for DRL with the ability to flash it instead of the HID when it isn't on. This is a big mod and required couple weeks of planning around the factory wiring diagram, but the results are totally worth it.
Just by looking at TRFS seems like FX-R is still the cheapest.
Need M12x1.25 tap ASAP!
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
