Originally Posted by wylee
So the 98/99 cam sprocket definitely will not bolt onto the 2000+ camshaft?
it will bolt on to the camshaft, but thats not the problem. the 2000+ uses coil on plug setup, and has a set of 4 flying magnets on the end of the intake cam to trigger the ecu to fire. the 98-99 only has 2 flying magnets. not to mention the vvti holes would spray oil everywhere and you would have low oil pressure.
honestly it would be just easier to swap to vvti, plus you would get a higher redline if you used all the newer corolla stuff. and have more power.
