If you just want to change the lights, you don't need to remove the entire thing. First, remove your ashtray. Then pull out on the trim around where it was. You can pull it out just enough to change the ashtray light (use part #74) and the cigarette lighter ring light. For that one, you'll need to use a universal light and wire it in. Reinstallation is reversal.
For the AC and heat control lights you'll need to remove your stereo. Either 2 or 4 screws. The bulbs are directly below, two #74. The green light on the AC that only lights when the button is depressed, is soldered in. Good luck.
2000 Silver Corolla LE
Carbon fiber altezzas, reverse indiglo gauges, blue LED interior/swapout, clear corners, xenon headlights/corners, MP3 deck, alarm w/ battery backup & pain generator, mesh grill and repainted exterior.
