normally, crowbar, yes it is. but if you remove your oil filler cap; which has an O-ring on it for a reason, you create a bigger and more convenient release for your crankcase vapor. this is a vacuum leak and your car will run funny from it. not to mention you'll be polluting massively. in short, there's a reason why every book says to check and add oil with the engine off, that and the whole 'your dipstick reading will be WAY off'
before you ask a 'how do i...' question answer this for me. do you own a repair manual for it? have you searched the forum for a similar issue?
SEARCH THE FORUM BEFORE YOU POST!
