the only time i had to remove mine was when i was swapping the engine, so the fans, and IM were already off. u can do it either way as u see fit, as u read in the other thread, both ways work.
the starter is located right under the intake manifold, pop the hood, look pass the aluminum manifold, u should see a cylinder shaped thing lying horizontally. that's your starter.
the starter is held on by 2 bolts threaded in from opposite sides, meaning, 1 bolt threaded in from the left through the block and into the started, the other threaded through the starter and into the block. the starter itself has a connector on it, and a wire held on by a 10 mm nut (you have to disconnect them from under the car, as both of them are located under the starter), disconnect those 2, and take the bolts off, the starter should slide right out.
05 engine under a 00 hood! Another 8th gen is back on the road!
