How do I install a 99 Corolla radio in a 99 Prizm (pictures attached)? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-26-2010, 01:38 PM   #1 (permalink)
View Mithridates's Photo Gallery
Question How do I install a 99 Corolla radio in a 99 Prizm (pictures attached)?
99 Prizm (note how the vent controls are above the factory radio, which appears to be a double DIN slot):
99 Corolla (note how the vent controls are below the factory radio (which appears to be a single DIN slot):
Radio to be installed (front):
Radio to be installed (back):
I believe the solution involves one of these Metra kits (for physical spacing):
What I can't figure out is what to do with the wiring. How does my single plug Prizm wire harness fit into the two (circled in red) Corolla radio jacks?
Mithridates is offline   Reply With Quote
Old 01-26-2010, 05:05 PM   #2 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291252
View gold94corolla's Photo Gallery
It should be pretty easy. The single din unit should bolt right into the either the top or the bottom of the double din spot. Don't take my word for it though. As for the wiring, you'd be lucky if it matched. The best thing would probably be to cut all the wires and solder them to the right places... you're lucky if the wires are all the same colors and stuff, making the switch easy. I think that the wires are in deed the same.... I have swapped many parts between Corollas and the Prizm, and this was the case. Good luck.
gold94corolla is offline   Reply With Quote
The Following User Says Thank You to gold94corolla For This Useful Post:
Mithridates (01-26-2010)
