Drain plug gasket sticking to oil pan - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-27-2010, 06:33 PM   #1 (permalink)
View Braddale's Photo Gallery
Changed the oil and filter for the first time by myself a few months ago.
After changing I realized the drain plug washer had stuck to the oil pan. Now I am a bit worried that it will be hard to remove from the pan, this time I will wear my glasses.
Would it not pop off pretty easily by tapping it lightly on the side?
Braddale is offline   Reply With Quote
Old 01-27-2010, 06:37 PM   #2 (permalink)
Toyota Tech in training!
View Downhillzze110's Photo Gallery
should. if not use a screwdriver to pry it off. the oil pan is steel, the washer is Dead Soft Aluminum; you'll ruin the washer before you ruin the pan. if you do happen to ruin the drain plug gasket you can get a new one for CHEAP at ANY parts house.
hope that helps.
oh and btw the drain plug washer sticking to the pan indicates that its doing its job
before you ask a 'how do i...' question answer this for me. do you own a repair manual for it? have you searched the forum for a similar issue?
SEARCH THE FORUM BEFORE YOU POST!
Downhillzze110 is offline   Reply With Quote
Old 01-27-2010, 06:45 PM   #3 (permalink)
View mr1114's Photo Gallery
No need to change it if its not leaking IMO. I've never had a problem with a leak from not changing a washer.
2006 Corolla S - sold
2003 Solara SLE - sold
2000 Corolla LE - sold
mr1114 is offline   Reply With Quote
Old 01-27-2010, 07:08 PM   #4 (permalink)
neither have i. but occasionally i'll wreak some accidental damage upon one to the point that it can no longer seal. thats when you need to replace it
