2000 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2010, 11:47 PM   #1 (permalink)
View manev's Photo Gallery
2000
Have code for o2 lean and misfires, replaced plugs still runs ruff, would o2 sensor cause engine to misfire ?
manev is offline   Reply With Quote
Old 02-02-2010, 01:44 PM   #2 (permalink)
Gearhead
Gameroom cash: $196215
Need more info - year and mileage? Any mods to the car? Did this just start recently or has the car been running rough for some time? Maintenance history of the car?
Old 02-02-2010, 02:00 PM   #3 (permalink)
View buci's Photo Gallery
It's not likely an O2 will cause the misfire. Do a complete tune up on the car before starting to change things.
buci is offline   Reply With Quote
Old 02-02-2010, 08:15 PM   #4 (permalink)
2000 Corrola
Bought 2000 Corolla with 129,000 miles, failed inspection due to Random misfire and lean o2 bank one. Put in new plugs and 2 new coil over plugs $90 each and pvc valve. Car still runs rough especially when cold. Car will pause when pressing hard on the gas then slowly pick up.
Old 02-03-2010, 11:19 AM   #5 (permalink)
View rgurleyjr's Photo Gallery
Go to Autozone or Advance and get your codes checked.
rgurleyjr is offline   Reply With Quote
Old 02-03-2010, 11:29 AM   #6 (permalink)
View phantazn's Photo Gallery
bad readings from a dying o2 sensor may tell your ecu its running lean when its not, and flood the cylinders with way too much fuel, thereby causing misfires. just had this same problem on an 01 rx300.
phantazn is offline   Reply With Quote
Old 02-03-2010, 05:30 PM   #7 (permalink)
Dashboard Jesus Chicken
iskate631's Avatar
View iskate631's Photo Gallery
i had a slightly similar problem a little while back, the rear o2 sensor went and caused the idle to be way out of whack, and another time my wires went the gas pedal choked up a bit when i stepped on it at a low rpm
iskate631 is offline   Reply With Quote
Old 02-06-2010, 08:11 AM   #8 (permalink)
Replaced front 02 sensor, new plugs and PVC valve, cleared codes for misfire and lean bank 1. Still runs ruff, stalls when hitting the gas hard. Light came back in one day with the same codes for misfire and lean. Now what ?
Old 02-06-2010, 12:35 PM   #9 (permalink)
Gameroom cash: $201383
View teppista881's Photo Gallery
Try cleaning your MAF sensor. Unplug battery and sensor, unscrew sensor, and blast it with MAF sensor cleaner. Let dry, reinstall. I do this at least once a year to keep the lean code (p0171) away.
You might also check for vacuum leaks around the intake.
teppista881 is offline   Reply With Quote
