break pad - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-02-2010, 10:41 PM   #1 (permalink)
Gameroom cash: $371570
View ilovecorollale's Photo Gallery
break pad
i notice that my brake pad that is holding my brake is kind of loose...i mean if u wiggle it with ur strength a little it would kinda wiggle a little up down left right and i tried to tighten the 2 bolt onto the brake pad but it wouldnt go any further ...any idea...?
its not tight on like my bros civc....and i was thinking maybe the bolt was too long but the bolt seems to be perfect length.thnx
ilovecorollale is offline   Reply With Quote
Old 02-02-2010, 11:06 PM   #2 (permalink)
ロンリードライバー
Gameroom cash: $224935
View all2baka's Photo Gallery
What are you referring to as the "brake pad"? As in the actual brake pads? What you're describing is the calipers.
1. Look at how much of the brake pads are left and if it's very little then you'll need to change them.
2. Take pics so we can take a look at it, words alone are difficult to figure out from how you're describing it.
3. You probably just need to change your brake pads because they're worn out.
all2baka is offline   Reply With Quote
Old 02-02-2010, 11:28 PM   #3 (permalink)
Well i still have a lot of brakes left and yes i mean the actual brake pad that is held on by two 14 mm bolt.
Old 02-03-2010, 07:13 AM   #4 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
probably worn out slides or worn out slide holes. try replacing the caliper and bracket with a rebuilt one.
Old 02-07-2010, 11:35 AM   #5 (permalink)
View GaryGoatse's Photo Gallery
if you grab the pads with some force then yeah they should wiggle. if you are grabbing the caliper and slidding it towards you and away from you then yeah that means the slides are working. On my corolla (99') they are loose and they squeeled so i used some anti-sieze compound and everything is fine. i don't think it's anything you should worry about unless they are very loose
GaryGoatse is offline   Reply With Quote
Old 02-07-2010, 09:02 PM   #6 (permalink)
Well i aint worry much about it but thought i just mention about it to see if there's anything common out there. thnxs
