Grinding sound - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2010, 10:45 PM   #1 (permalink)
View SilverNitrate's Photo Gallery
Grinding sound
My 99 rolla have this grinding sound whenever the wheel is turned all the way to the left especially when I am making U turns...sounds like a grinding from a back plate to my rotors....anybody had this experience? Any fix?
SilverNitrate is offline   Reply With Quote
Old 02-07-2010, 11:13 PM   #2 (permalink)
Dashboard Jesus Chicken
iskate631's Avatar
View iskate631's Photo Gallery
does it do it when the car is at a complete stop? is the grinding louder or changes speed depending on how fast you are driving?
iskate631 is offline   Reply With Quote
Old 02-07-2010, 11:49 PM   #3 (permalink)
no grinding at all, jut when i have to take a sharp turn or u turn. once my wheel is straight, it's fine.
Old 02-08-2010, 12:01 AM   #4 (permalink)
Gameroom cash: $120800
View Milky's Photo Gallery
sounds like your wheel might be rubbing on something when its at or near full lock. what size tires are you running?
Milky is offline   Reply With Quote
Old 02-08-2010, 09:10 AM   #5 (permalink)
View phantazn's Photo Gallery
pop off the hubcaps and make sure one of the lug nuts didn't work its way loose.
phantazn is offline   Reply With Quote
Old 02-08-2010, 01:01 PM   #6 (permalink)
full lock. I am using kumho 16's for my TRD wheels. same size as before. It doesn't sound like tire rubbing against a fender or the plastic shield. It sounds like metal grinding.
Old 02-08-2010, 09:05 PM   #7 (permalink)
hmm. with the front end jacked up and supported, turn the wheels to full lock. have a buddy hold the wheel at full lock. see if anything is touching. if its not, then i would check the wheel bearings for play.
