Hello,
I just bought a used 2000 Chevy Prizm, which I am told is the same as the Corolla. About a month after I bought the car, the CEL came on. The scope I rented from the auto parts store read the code as PO171 (Bank 1) System Too Lean. I was advised that there was a tiny chance it was the catalytic converter, except that the car has no power issues whatsoever, and it does not stink when running, like a clogged cat would suggest. I was also told that it might simply be a clogged MAF sensor, and that a quick hit on the wires with carb cleaner might do the trick. Of course, the suggestion of the O2 sensor itself came up, but the guy at the auto store didn't think so.
The
only problem I have noticed is that after I drive it for a while, then stop and park for a bit, then get back in, it seems to have trouble turning over again. Usually it takes me two or three tries to get it lit again, but after that, no problems running at all. It comes up to full power in no time, and literally flies down the highway. I have taken in all the way up to 90 MPH (not for too long, obviously, to avoid an accident and/or ticket), and it does so with no problem or hesitation at all.
In ever respect, the car seems to run perfectly, with no issues other than the starting when warm thing.
Other than that, I really love this car, and I am hoping it will be an easy fix.
Any suggestions?
Thanks!
