First check the oil level, second remove serpentin belt and start car dont run it for long just check the noise is gone.If the noise still there locate IAC valve conector is on the bottom of throttle body disconect it while running , your RMP should raise and noise should be gone .In my option is IAC Idle Air Control Valve when getting old start to vibrate and with air passing make that crazy noise.You will get check engine light to reset disconect one batery terminal for 30 seconds.
