Engine stalls, then shuts down with window defroster on! HELP - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-17-2010, 03:42 PM   #1 (permalink)
NEWBIE
View topgun6521's Photo Gallery
Unhappy Engine stalls, then shuts down with window defroster on! HELP
Hellooo there. I need some help. I just got a 2001 corolla LE a week ago. Three (3) days ago I changed the air filter, had a engine flush done, replaced engine oil, transmission oil didn't need change.(will change spark plugs and wire next week). Everything great! until today when I went to get the car NYS inspection sticker. The car passed with no problems. But now when I turn on the window defroster, the car RPM goes up to 2.5 or so and then down and up a couple of times and then engine turns off. I can get the regular heater on and it works with no issue. What could be causing this issue? Thank you in advance.
topgun6521 is offline   Reply With Quote
Old 04-07-2010, 12:27 PM   #2 (permalink)
'95 Previa S/C AWD Driver
AlaricD's Avatar
Gameroom cash: $150452
View AlaricD's Photo Gallery
The rear window defroster (electric grid)? Check the alternator.
The front window defroster (fan-forced air)? Check the A/C compressor. (I expect that turning the A/C on will result in the same problem. On the '01 LE (like most newer cars), the A/C comes on when you run the heater in the defrost position.)
AlaricD is offline   Reply With Quote
