Help on oil change for my corolla.
I need to change my oil at 3000 miles, so far my 1999 corolla is at 119,000 miles. What is the best type of oil I should use? synthetic vs conventional? I heard conventional is good enough because corolla's don't need the expensive stuff...is it true? And if conventional what type should I use? I keep hearing people say 10w-30, 5w-30, 15w-30, 20w-40....what does all these numbers mean?? thanks, any advice is appreciated.
more info if this helps, i live in NYC where summer is around...85-100 winter can go below 20 degrees and average 50-70 degrees most of the time in spring or fall. Don't do any towing just regular weekend use not even commuting to work with my car. automatic transmission...2wd...
