Fog Light Corolla S 2001 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2010, 01:22 PM   #1 (permalink)
Tolargo S
View tolargo12's Photo Gallery
Hi To all,
I'm new in this forum and i already like it so much. This time my concern is:
I would like to set the fog lights independent of the the high beam no matter if is in the low beam i just want to not have the high beam on to be able to turn on the fog lights. if one of you can help me to do that I will really appreciate.
Thanks
tolargo12 is offline   Reply With Quote
Old 02-20-2010, 01:39 PM   #2 (permalink)
Dashboard Jesus Chicken
iskate631's Avatar
View iskate631's Photo Gallery
there is a number of ways you could do this. im actually surprised your car doesnt have a fog light toggle on the blinker/headlight switch. my 02 has one stock so it is on or off when i want it. but since you dont, you could go a few other ways. a way i have heard with things like halos is people want them on when the parking lights are on, so you can simply splice it into the parking lights power wire. you could do the same with the fog light, this way you will have fogs with parking lights, low beams, and high beams. saying that you dont care they are on all the time. another way is you could make your own switch inside the car to turn on the fog lights. you could splice a wire off of the fog lights power wire and run it through the engine compartment-thru the firewall-into the interior of the car. then just connect that wire to an aftermarket switch.
- 5% Window Tint
- Injen SRI
- Smoked Headlights/Taillights
iskate631 is offline   Reply With Quote
Old 02-20-2010, 01:55 PM   #3 (permalink)
Tolargo S
Sorry I wasn't too clear it has the fog light toggle on the blinker/headlight switch, but what i mean is i.e. if i have the low beam (one touch) light on i'm not able to turn on the fog lights. i must have the high beam(tow touch) on to be able to turn on the fog lights and there i can turn it on or off if i want. and that is what i don't want.
Old 02-20-2010, 04:35 PM   #4 (permalink)
'95 Previa S/C AWD Driver
AlaricD's Avatar
Gameroom cash: $150452
View AlaricD's Photo Gallery
Whoever installed your fog lights did a terrible job. Fog lights are useless in conditions that warrant the use of high beams; high beams are useless (and detrimental) in conditions that warrant the use of fog lights.
Sadly, if it was installed that way at the factory or by the dealer at the time of original sale it may still be difficult to get the dealer to correct it under warranty, since the car is well beyond the 3/36 mark.
AlaricD is offline   Reply With Quote
Old 02-20-2010, 04:48 PM   #5 (permalink)
iskate631's Avatar
thats odd... i havent heard of that before. alarc is right it must be wired wrong if that is the stock toggle switch. cause my 02 lets me turn them on or off at any time. like when i pull in home too late at night i turn off all my lights including parking lights but leave my fogs so i can see my way so my parents dont see my headlights hahaha
- 5% Window Tint
- Injen SRI
Old 02-20-2010, 05:07 PM   #6 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $295773
View Buurin's Photo Gallery
The factory setup is:
Tail lights must be turned on to turn on fog lights.
Fog lights will be turned off when you turn on high beam.
01 S should have fog lights standard from factory. Fog lights should be easily installed on any 01 or 02 as they are already wired for them.
FWIW I also retrofitted 01 factory fogs into my 99 which never had fogs even as an option.
In conclusion, OP is either looking at an S with factory fogs but has electrical problems, or he has a one without factory fogs and the aftermarket installer botched the installation, which shouldn't need to happen if he indeed has an S.
Need M12x1.25 tap ASAP!
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 02-20-2010, 05:29 PM   #7 (permalink)
iskate631's Avatar
oh true. i disabled my drls and auto lights so i can turn the fogs on independently without any other light on. sounds like buurin hit the spot on the answer.
- 5% Window Tint
- Injen SRI
Old 02-20-2010, 10:04 PM   #8 (permalink)
View jay0016's Photo Gallery
Your switch could be bad this was the problem when i first got my car the fogs would only turn on when in high beam wierdest thing replaced the switch and they work like a charm
If i'm understanding your problem correctly
jay0016 is offline   Reply With Quote
